Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Honda Crv Car Shakes
Auto Repair2001 Toyota Corolla Vio...
Auto Repair1999 Honda Crv Car Won'...
Auto Repair1989 Acura Integra
Auto Repair2003 Honda Crv Engine L...
Auto Repair1991 Acura Integra Loud...
Auto Repair2000 Saturn Sl1 Taking ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2006 Pontiac G6 Fuses
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Feb 01, 2008 12:41 pm
By ciaopsex69, New to the forum
Give Feedback | Votes: 0
Electrical problem
2006 Pontiac G6 6 cyl Front Wheel Drive Automatic 38746 miles
I wa replacing a fuce 3 and 16 PCM and now my auto lights wont come on i checked the fuses and they all seem fine and when you open the door the window slides down and when you close the door the window supposed to go back up but now it doesnt, i have no clue what happened the 3 and 16 that i took out seem fine my brights work but my normal beem and my windowns wont go back up i disconected my battery as well. Please tell me what is going on and what i can try to do
Find a car repair manual for your Pontiac G6 Repair Question.
Posted at Sat Feb 02, 2008 9:25 am
By brian 1, Tech level 3
Reputation: 21.6 (22) Give Feedback | Votes: 1
why did you replace fuse 3 and 16? need a little more info.I'II try to answer as best I can.you still might have a blown fuse for the lights.did you check the fuse block in the trunk,there is fuses in the trunk.as far as the windows you have to re-initialize the windows.because you disconnected the battery the windows loose there memory.here is how to re-initialize the windows.(I assume you have a convertable or 2 door model)this will not work on 4 door models.try thisImportant: You MUST have the Convertible top up before starting the re-initialization.
Close the door.
Raise the window by pulling the power window switch up.
Hold the window switch up for two seconds after the window is closed. Release the switch. Then hold the switch up again for two seconds.
Lower the window all the way down. Hold the switch down for two seconds.
Repeat the procedure for each window, including the rear quarter windows on convertible models, until all windows are initialized.
I hope this helps.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
