Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Ford Ranger Four W...
Auto Repair1986 Pontiac Firebird C...
Auto Repair1997 Ford Ranger Fuses ...
Auto Repair2001 Honda Crv
Auto Repair1994 Ford Ranger Blower...
Auto Repair2003 Dodge Dakota Heat ...
Auto Repair1994 Ford Ranger Wiper ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2006 Pontiac G6 BODY CONTROL MODULE
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Oct 02, 2008 2:35 am
By CHUCK NEWBERRY, Have Donated
Give Feedback | Votes: 0
Computer problem
2006 Pontiac G6 4 cyl Front Wheel Drive Automatic 45000 miles
I RECENTLY PURCHASED A 2006 PONTIAC G6 THAT WAS PREVIOUSLY A RENTAL CAR. THE CAR DID NOT HAVE A KEY FOB. THE DEALER PURCHASED A KEY FOB AND CARRIED IT TO THE LOCAL PONTIAC DEALER TO PROGRAM IT. LONG STORY SHORT, THEY COULD NOT PROGRAM IT BECAUSE THEY SAID THE BCM HAD BEEN "LOCKED" BY GM AS PER THE RENTAL COMPANY. THEY TELL ME I HAVE TO BUY A NEW BCM TO FIX THE PROBLEM. THEY ALSO SAID A USED ONE WOULD "PROBABLY" NOT WORK BECAUSE THE PROGRAM IN IT COULD BE "LOCKED" ALSO. I JUST THINK WITH TECHNOLOGY BEING THE WAY IT IS THAT I AM GETTING THE RUN-AROUND. DOES THIS STORY SOUND TRUE?
Find a car repair manual for your Pontiac G6 Repair Question.
Posted at Thu Oct 02, 2008 4:57 am
By mmprince4000, Moderator
Reputation: 72.8Reputation: 72.8Reputation: 72.8Reputation: 72.8 (73) Give Feedback | Votes: 4
DId you have the seller contact the rental company?
They should either unlock the BCM or provide the seller with the appropiate codes to unlock it, or provide you with a new BCM at no charge.
Posted at Thu Oct 02, 2008 5:57 pm
By brian 1, Tech level 3
Reputation: 21.6 (22) Give Feedback | Votes: 1
it is true,once the bcm is programmed the info is "locked".the only way is to replace and reprogramm a new bcm.A new body control module (BCM) must be programmed with the proper regular production option (RPO) configurations. The BCM stores the information regarding the vehicle options and if the BCM is not properly configured with the correct RPO codes the BCM will not control all of the features properly. The Tech 2 software will automatically prompt you with the various RPO's available for the vehicle. Use extreme care when verifying both the VIN and Odometer reading that is set in the service BCM. Once the VIN and Odometer are set in the replacement BCM it is impossible to change them, and if there is a mismatch, the part will be rendered useless. you could ask the dealer to see if they can change the rpo options in the bcm.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
