Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2006 Other Isuzu Models fluid analysis
Posted at Tue Feb 09, 2010 6:39 am |
By
gordie01,
Have Donated |
Give Feedback | Votes: 0 |
Transmission problem
2006 Other Isuzu Models 4 cyl Two Wheel Drive Automatic 63,000 miles
Fluid tests were conducted on a vehicle that I am interested in. It is a medium duty Isuzu NQR with an automatic trans. Below are the results. What does this tell me?
Silicon 28 PPM
Lead 10 PPM
Tin 15 PPM
Copper 286 PPM
Aluminum 50 PPM
Silver 0 PPM
Nickel 0.5 PPM
Chromium 0.2 PPM
Iron 83 PPM
Glycol N/A
Water NEG
Fuel N/A |
Find a
car repair manual for your Other Isuzu Models.
Posted at Tue Feb 09, 2010 7:28 am |
By
racefan966,
Certified 2CarPros Technician |
     (2937) Give Feedback | Votes: 44 |
Well which fluid does this pertain to? |
Find a
Posted at Tue Feb 09, 2010 8:11 am |
By
gordie01,
Have Donated |
It is the report for the transmission fluid. |
Find a
Posted at Wed Feb 10, 2010 7:54 am |
By
racefan966,
Ok it sounds like it is tranyfluid with a few miles on it. It has some metals in it, as the transmission and fluid gets mileage on it this is normal, this is why the fluid and filter should be changed every couple of years. The way I check fluid out is with the chart below as when trans fluid goes bad and the trany is having problems the fluid color changes. So here is the chart that I use. The numbers are in parts per million.
Transmission fluid chart. what color is yours?
Find a
Posted at Wed Feb 10, 2010 8:15 am |
By
gordie01,
Have Donated |
This is a unit I am looking to purchase. If I purchase this unit would you suggest me changing the tranny fluid before I drive it 1800 miles based on the metal numbers? I can not answer your question on the look of the fluid as I am not with the vehicle. |
Find a
Posted at Wed Feb 10, 2010 8:32 am |
By
racefan966,
Ok when looking to buy a vehicle I suggest a compression test and check all belts and fluids for color. Do they look new or old and neglected. How does the anti freeze look and brake fluid(is it black or clean flush as needed) and engine oil and so on. I also like to check the brakes for wear and check u-joints for tightness and front end for any signs of worn parts and tires for signs of uneven wear. If you buy this truck I recommend changing engine oil, transmission fluid and fuel filter and check air filter and spark plugs. This way you will know where the maintence is. As you know vehicles are mechanical so they can break at anytime without warning too. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
