Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2006 Infiniti G35 Suspension, brakes or something else
Posted at Fri Dec 25, 2009 11:12 am |
By
dbjdpb,
Have Donated |
Give Feedback | Votes: 0 |
Noises problem
2006 Infiniti G35 6 cyl All Wheel Drive Automatic 43600 miles
I have an 06 G35 AWD and purchased it used recently. There are a few minor signs that it might have been in a bump up and never recorded as such but I cannot be certain. At any rate, the vehcile handles well and does well but one thing bothers me. Often upon starting out it makes an annoying creaking noise that seems to come underneath, passenger side front when initially braking or hitting minor bumps. Sometimes it seems to come mid to rear but most often the passenger front. I don't notice it when drivng normally after starting although it may do it occasionally. It just creaks and I have had one shop look and could not find anything. They stated that they lubricated the bushings but it did not resolve the issue. Any thoughts? |
Find a
car repair manual for your Infiniti G35 Repair Question.
Posted at Fri Dec 25, 2009 2:31 pm |
By
ImpalaSS,
Certified 2CarPros Technician |
  (1271) Give Feedback | Votes: 32 |
Hello –
To assist you better is your model just the G35 or G35x and what is your engine size in liter?
Thank you very much for the donation
Have a very Merry Christmas and a safe New Year
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions. |
Find a
Posted at Fri Dec 25, 2009 2:52 pm |
By
dbjdpb,
Have Donated |
It is a 3.5 Liter 6 cyl and I believe it to be an X. It is AWD. The creak is the best description of the sound and often times it seems related to braking. |
Find a
Posted at Fri Dec 25, 2009 11:01 pm |
By
ImpalaSS,
Hello –
First, congrats on your new car………..very nice looking.
Next, try checking CarFax below and that should tell you the history on the car……or at least it is pretty reliable.
http://www.carfax.com/
Okay………what it may be is the compression rod. Below is a pic of it. There is a Technical Service bulletin on “NOISE FROM FRONT COMPRESSION ROD” This may be the problem.
TECHNICAL SERVICE BULLETIN
Reference Number(s): ITB08-013, Date of Issue: March 10, 2008
INFINITI: 2004 - 2006 G35 Coupe; 2004 - 2006 G35 Sedan
CLASSIFICATION: FA08-001
APPLIED VEHICLES: 2004 - 2006 G35 Coupe (CV35); 2004 - 2006 G35 Sedan (V35)
Related Ref Number(s): ITB08-013
ARTICLE BEGINNING
IF YOU CONFIRM
There is a noise coming from the front compression rod.
And
The bushing is damaged.
ACTIONS
Replace only the bushing, not the compression rod assy. for this issue.
I would have the shop you took it to check out this TSB to see if this is the problem and then if it is refer to the TSB for the repair.
If that isn’t it let me know and we will try to look at other things.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
