Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
2006 GMC Yukon rear hatch
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Sat Jul 12, 2008 5:04 am |
By
Handshake,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
2006 GMC Yukon V8 Two Wheel Drive Automatic
I too have a rear hatch problem. Rear hatch latch or rear glass will not open. HELP!!!!
| Find a
car repair manual for your GMC Yukon Repair Question. |
Posted at Tue Aug 05, 2008 6:45 am |
By
Handshake,
Have Donated |
| 2CarPro Jack wrote: | | Need to remove the interior panel and inspect the latch assembly,Im thinking a plastic connector broke and the rod wont release. Can you hear it make noise when you try to release it with the button? |
Yes, panels removed it sorta wiggles when I attempt to lock/unlock
| Find a
Posted at Tue Aug 05, 2008 11:09 am |
By
Handshake,
Have Donated |
| 2CarPro Jack wrote: | | Try manually pulling on the cables where they hook to the mechanism to see if you can make them release the latch |
The black arrow is able to be moved to lock or unlock the mechanism...the red arrow does not rotate when the button is pressed to lock or unlock...it does wiggle when the lock/unlock button is pressed.
| Find a
Posted at Wed Aug 06, 2008 4:30 am |
By
Handshake,
Have Donated |
| Handshake wrote: | | 2CarPro Jack wrote: | | Try manually pulling on the cables where they hook to the mechanism to see if you can make them release the latch |
The black arrow is able to be moved to lock or unlock the mechanism...the red arrow does not rotate when the button is pressed to lock or unlock...it does wiggle when the lock/unlock button is pressed. |
pulling the cables doesn't help. It appears that the lock actuator and motor are one piece. If this is so, then I might try replacing this assembly. Like I mention when you press the lock/unlock the lock actuator wiggles but does not engage.
| Find a
Posted at Wed Aug 06, 2008 6:53 am |
By
Handshake,
Have Donated |
| 2CarPro Jack wrote: | | I understand that. Unhook the cables, i want to be sure that the latches arent keeping the motor from working |
Done....nothing!...Its like the motor wants to turn the mechanism but won't. Sounds like we are getting close...
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
