Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2003 Dodge Dakota Heat ...
Auto Repair1994 Ford Ranger Wiper ...
Auto Repair2004 Mercury Sable Spar...
Auto Repair2007 Honda Crv 2007 Hon...
Auto Repair2001 Pontiac Grand Prix ...
Auto Repair2007 Honda Crv Sterring...
Auto Repair2005 Honda Crv Noise In...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2006 GMC Yukon Rear Door Lock
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jun 06, 2008 4:08 pm
By gmcman4387, New to the forum
Give Feedback | Votes: 0
Electrical problem
2006 GMC Yukon V8 All Wheel Drive Automatic
Just out of no where the rear hatch will not work what so ever. I cant get the lock to unlock with the wireless key and it has no entry for a key on the hatch. The glass also will not open or even make a sound...Now all of the other doors and windows on the other 4 doors work fine no problems what so ever..It sounds like a short to me but this suv is so new and well taking care of.... im leaning to maybe a faulty relay..i looked under the hood and at the one box in the interior but no luck for door locks..any help would be great ty for your time
Find a car repair manual for your GMC Yukon Repair Question.
Posted at Tue Jul 15, 2008 10:28 am
By Handshake, Have Donated
gmcman4387 wrote:
Electrical problem
GMCMAN please email me at Handshake@bellsouth.net
Posted at Thu Jul 17, 2008 4:23 am
By Service Writer, Certified 2CarPros Master Technician
Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6Reputation: 536.6 (537) Give Feedback | Votes: 72
Under warranty?
First, check the fuse in the instrument panel fuse box labeled ECC. This 10 amp fuse is on a separate circuit than the others.
Posted at Thu Jul 17, 2008 9:42 am
Service writer, the ECC 10 amp fuse appears ok, would there be another fuse I could try. he Yukon is out of warranty.
Posted at Fri Jul 18, 2008 2:12 am
You can check these. Swap them out with another fuse of the same to be sure. Same goes for the ECC.
You may need to manually open the liftgate to get at the components inside the door to check for wiring problems or bad connections. Check any harnesses that are bent on a tighter radius that will flex when the gate goes up and down.
From what I understand, the latches on these can be troublesome and should get lubricated. Granted I have not run into this problem on these at our shop.
Posted at Mon Jul 28, 2008 6:08 pm
Service Writer, I believe we are getting close, but no cigar just yet. The 06 Yukon does not conform to the Fig.10 diagram ( opening liftgate during electrical panel)....It does have a pull down strap that the owner can use when closing the hatch. This strap uses a small hex head type screw. Upon removing this strap it makes it easier to pop out the bottom panel and expose all of the workings. Once you manual unlock the level you can utilize the push button for the glass or the level for the hatch. I sprayed the workings with WD-40 and noticed while using the remote lock the mechanism appears to wiggle. This tells me that it is not fuse related but more of a failure of the lock/unlock mechanism. Should I continue to track down electrical/fuse or does it also seem it is the lock/unlock mechanism?. I may try to decipher uploading a picture if this will help. Thank you again, we are close. Handshake
Posted at Sat Aug 02, 2008 5:26 pm
here is the picture of the mechanism......
Posted at Wed Aug 06, 2008 10:39 am
By shawnamyler, New to the forum
I am having the exact same problem. However, I was unable to remove the panel in fear of damaging it. Please let me know if you find a fix.
Posted at Wed Aug 06, 2008 4:16 pm
Does this look like what you have?
IF there is no noise at the actuator, then this is still electrical, other wise you would hear or see a reaction when the button is pressed.
Test for power at the arrows, I expect none. This is the flow chart:
Check for power going into the actuator harness, IF present, I would expect the actuator to be bad.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
