Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1996 Chevy Monte Carlo W...
Auto Repair2003 Mitsubishi Montero
Auto Repair1984 Volkswagen Rabbit 1...
Auto Repair2004 Ford Expedition Con...
Auto Repair2000 Nissan Xterra Speed...
Auto Repair1991 Toyota Pickup Fuel ...
Auto Repair2000 Nissan Frontier Tru...
Auto Repair2001 Toyota Sienna Stuck...
Auto Repair2000 Chevy Silverado Not...
Auto Repair2002 Hyundai Santa Fe St...
Auto Repair1988 Ford Bronco Will No...
Auto Repair94 Pontiac Grand Am 2.3 Q...
Auto Repair1997 Other Plymouth Model...
Auto Repair2001 Ford Windstar Shutt...
Auto Repair1999 Lincoln Continental ...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2006 Acura RSX wheel nuts
Posted at Wed Apr 02, 2008 5:13 pm
By edwardsharriman, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2006 Acura RSX 4 cyl Front Wheel Drive Manual 20000 miles
I cannot seem to budge my port wheel nut (holds the hub to the axel / drive shaft). I have tried both directions. I use a 4 foot bar and weigh nearly 250
myself. This doesn' t seem right.
Are the port side nuts 'reverse threaded'? Any ideas
on how to break it loose? I have a 550 foot pound
impact wrench and it won't do it either!
thanks,
ward
Find a repair manual for your Acura RSX Repair Question.
Posted at Wed Apr 02, 2008 5:42 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 111.5Reputation: 111.5Reputation: 111.5Reputation: 111.5Reputation: 111.5Reputation: 111.5 (112) Give Feedback | Votes: 23
are you first of all doing this with the wheel on and the vehicle on the ground? it is counterclockwise, at least all the vehicles ive ever done this to is, to loosen so its regular thread, are you sure the cotter pin is removed from it and its not snapped off in it? soak it with penetrating oil also if possible heat it up with a torch, but make sure everything is disconnected first...and only use it if the penetrating oil and a longer bar doesn't work.
im surprised your 550 ftlb impact cant loosen it!
usually they loosen right up for me with a 3 foot breaker bar.
check the threads just in case it is clockwise thread, put a needle on the threads and go around it counter clockwise, if it loosens then its a regular thread, if it tightens then its opposite threaded.
Posted at Wed Apr 02, 2008 6:30 pm
Replied by author in different post, moved here to continue
Yep, I'm doing it with the wheel on the ground.
I just broke my 1/2 socket drive.... must be pretty
stuck!
The penetrating oil hasn't made any difference. I let it soak for a couple hours.
How much heat might this need? I only have a MAP gas tourch... I doubt that'll heat it enough.
I'm pretty certain it is a left handed thread. I guess I can go to the dealer and buy the nut and see that way. There isn't much thread showing past the end of the nut."
Posted at Wed Apr 02, 2008 6:37 pm
if i recall right it requires 500 foot pounds of torque to loosen then, are you using a 6 point IMAPACT socket to loosen it? i use a 3 foot breaker bar that i use on my home tractor with a really thick walled socket, and on the end of that i attatch another long pipe for leverage, it bends but it shouldnt snap on you.
try running your impact at a higher pressure.
Posted at Wed Apr 02, 2008 6:41 pm
maybe find a way to get a house jack to sit on it and pull up on it. if thers a semi truck repair shop near you anywhere, take it there and have them break it off for ya, then tighten it down get her home and reloosen. they are on there TOUGH
Posted at Thu Apr 03, 2008 4:54 pm
I finaly got my wheel nut off. I had to grind away one side of the nut and sacraficed the shaft. I'll have to replace it but such is life. Even after grinding half the nut away I broke my 1/2 socket drive AND my 1/2 inch breaker bar. Then I used an air hammer and a chisel and loosed up the remaining fraction of a nut. Turns out the previous mechanic had used thread cement.
When I spoke to him he said, "No one in my garage would ever use anything like that on a wheel nut. You must have had subsequent work done somewhere else."
Yet another reason to always do one's own work if at all possible.
Grrrrrrrrrr
Posted at Thu Apr 03, 2008 6:59 pm
the guy that did that was a moron, never heard of that to hold on the wheel nut, they are torqued on and a cotter pin hold it on anyways!
sorry to hear you had to sacrifice the shaft, and the 1/2 socket and breaker bar!
and THANK YOU VERY MUCH for the donation!
Posted at Thu Apr 03, 2008 7:53 pm
Oh.... no problem with the tools, its why I always
buy craftsman. I may break them more often BUT
the break is always temporary!
THanks for your help. Nice service you're providing,
happy to support it.
w
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
