Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Automobile Safety Inspection
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1993 Citroen Ax Intank ...
Auto Repair1996 Ford Taurus
Auto Repair1994 Chrysler Lhs Check...
Auto Repair2001 Acura Mdx Radio
Auto Repair1993 Pontiac Grand Am M...
Auto Repair1998 Cadillac Deville
Auto Repair1996 Toyota 4runner Par...
Auto Repair More Repair Topics...
We are the Auto Repair Experts!
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2005 Toyota Sienna Rear Evaporator Leak
Posted at Mon Oct 19, 2009 4:36 pm
By sk8tingusmc, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
2005 Toyota Sienna 6 cyl Two Wheel Drive Automatic 81000 miles
I have a rear air evaporator that leaks water into the inside carpet of the cargo area in rear of van. I have had it checked by toyota technicians and they can not figure it out. When the air is on water squeezes out the inside of the evaporator around the pipe and soaks the foam surrounding it. Then water drips directly into carpet below.
Find a car repair manual for your Toyota Sienna Repair Question.
Posted at Tue Oct 20, 2009 6:19 pm
By pear69, Moderator
(34) Give Feedback | Votes: 11
Is the A/C system fully charged with the proper refrigerent?
Posted at Wed Oct 21, 2009 5:50 am
yes it does have proper refrigerant. Everything about it works great, but it leaks water out the back evaporator. The toyota mechanics have no clue, but they think it is the expansion valve.
Posted at Wed Oct 21, 2009 9:58 pm
First, you must understand this, your evaporator is not leaking water. That is impossible! (it may leak refrigerant) but not water......
Evaorators, in an automotive A/C system, "evaporate heat" from inside the cabin, to the outside atmosphere. They do this by circulating refrigerant through the A/C system (which includes the evaporator). This refrigerant absorbes "heat" and releases it to the outside atmosphere....
Your issue, is the condensation that is a result of airconditioning.
There are many factors that can cause excessive condensation to build up on the evaporater. The most common is the level of the refrigerant.
How much refrigerant is in thre system?
Posted at Wed Oct 21, 2009 11:02 pm
By avenue723, Likes to hang around!
(9) Give Feedback | Votes: 0
EVERY A/C system has an evaporator- AND IT CONDENSATES which results in water dripping- THERE must be a water route for the evaporator- either a little hose, or a runway, something. Every car usually has a hose to let the water drip down to the ground. try looking for a runway or a hose-
every car that has a/c drips water
- try making a shield or something to direct water away.
Posted at Thu Oct 22, 2009 3:20 am
Sounds like a great idea. I actually came up with it myself yesterday. Thanks for the suggestion.
Posted at Thu Oct 22, 2009 8:57 pm
Every A/C system indeed has an evaporator, and the condensation must be drained out somehow; but A/C systems in cars are not new, and I am sure that the Toyota mechanics that you mentioned, checked out the drain system. If they didn't then they are not Toyota mechanics. You also mentioned that the mechanics think that it is the expansion valve. The expansion valve meters the amount of refrigerant that is allowed into the evaporator. If too much is allowed to go in, the evaporator will create too much condensation, which will - in turn - cause the drain to be overwhelmed with water...Re-engineering a new drain will not fix the problem.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
