Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2003 Ford Ranger
Auto Repair2002 Pontiac Grand Prix ...
Auto Repair1993 Ford Taurus Windsh...
Auto Repair2005 Gmc Canyon Gas Filter
Auto Repair1987 Ford Bronco
Auto Repair1997 Dodge Truck Turns ...
Auto Repair1995 Honda Civic Car Wa...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2005 Toyota 4Runner Multi-information display backlight off
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 15, 2008 9:42 pm
By 4RUNNER_2005, Have Donated
Give Feedback | Votes: 0
Interior problem
2005 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 30000 miles
I have a 2005 4runner, the multi-information display shows the time and temperature, however, on the left half of the display the backlight has turned off.
I can still see the time, but there is no backlight.
Is this a fuse or a light? can I fix it myself? if so, how?
Thanks..
Find a car repair manual for your Toyota 4Runner Repair Question.
Posted at Sat Aug 16, 2008 8:28 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
If this one is under the factory waranty, it's advisable to go to the dealer, it may need a new cluster.
Posted at Mon Aug 18, 2008 6:16 am
By lemoinekm, New to the forum
I've got a 2005 4Runner with the same problem - the left side of the mult information display doesn't have a backlight anymore. As 4RUNNER_2005 said, I can read the information, only the backlight is out. The 4Runner is no longer under warranty, so I'm wondering the same thing - is it just a light that I can fix myself?
Posted at Mon Aug 18, 2008 12:28 pm
I dont know if there are replaceable bulbs, but here's how to remove and overhaul it.
INSTRUMENT PANEL/METER -2005 Toyota 4Runner Limited
Page 1 of 2
COMBINATION METER ASSY
OVERHAUL
HINT:
COMPONENTS: See INSTRUMENT PANEL/METER
1. REMOVE INSTRUMENT CLUSTER FINISH PANEL SUB-ASSY a.Disengage the 7 clips. b.Disconnect the connectors and remove the instrument cluster finish panel sub-assy.
Fig. 37: Removing Instrument Cluster Finish Panel Sub-Assy Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
2. REMOVE COMBINATION METER ASSY a.Remove the 3 screws. b.Loosen the 2 bolts and remove the combination meter assy.
Fig. 38: Removing Combination Meter Assy
3. REMOVE SPEEDOMETER GLASS a.Remove the 2 screws. b.Disengage the 6 claws and remove the speedometer glass.
Fig. 39: Removing Speedometer Glass
4. REMOVE COMBINATION METER COVER NO.1 a.Remove the 10 screws and combination meter cover No.1.
Fig. 40: Removing Screws Of Combination Meter Cover No.1
5. REMOVE INCLINATION SENSOR ASSY a.Remove the 2 screws and inclination sensor assy.
Fig. 41: Removing Screws Of Inclination Sensor Assy
6. INSTALL COMBINATION METER ASSY a.Pull the positions shown in the illustration in the arrow mark direction to make the check pins unseen form the surface.
Fig. 42: Pulling Positions
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/18/2008
Page 2 of 2
b.Check that the connector on the instrument panel side is in place. c.Install the combination meter assy with the 3 screws. d.Tighten the screw shown in the illustration and check that the check pin protrudes.
Fig. 43: Tightening Screw
7. INCLINATION SENSOR ZERO DEGREE CORRECTION
NOTE:
 When replacing or removing/installing the combination meter assy and inclination sensor assy, be sure to perform zero degree correction of the inclination sensor.
 When performing zero degree correction, install the combination meter assy and perform it in level surface.
 Also perform zero degree correction when the body level setting is inclined because of vehicle height adjustment.
a.Turn the ignition switch off. b.While pressing the RESET switch, turn the ignition switch on. c.Within 5 seconds after the ignition switch is turned on, repeat pressing and releasing the RESET switch 3 times and keep holding the last press for more than 5 seconds. (Buzzer sounds for a second)
NOTE: If the buzzer does not sound, perform this procedure from the beginning.
d.Release the RESET switch when buzzer sounds. e.Press the RESET switch again and keep pressing for more than 5 seconds. (Buzzer sounds for a second again)
HINT:
 When the buzzer sounds twice, reset operation is completed.
 The buzzer sound of the first and second time is the same.
NOTE: If the buzzer does not sound or keep sounding for more than 1 second, perform the procedure from the beginning.
Fig. 44: Identifying Inclination Sensor Zero Degree Correction
© 2007 Mitchell Repair Information Co., LLC.
8/18/2008
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
