Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Drive Train Axles Bearings problem
2005 Pontiac G6 6 cyl Front Wheel Drive Automatic 50000 miles
how do i check to see if bearings are bad, lots of noise not the tires or the brakes
move wheel in and out from the top and bottom of tire, if it moves then its bad. also most often the only way to tell is to road test. while driving down road see if the noise goes away or gets worse when turniong left or right at about 30 mph. if it does then its a bad wheel bearing. this is a rumbling noise you are hearing right? if its a banging noise over bumps then check the sway bar end links
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
