Brakes problem
2005 Other Mercedes Benz Models V8 Two Wheel Drive Automatic 44,000 miles
How do you get the pins out of the calipers on a CL500 mercedes 2005, they have a small pin like end and the other is a flat end, each without bolt heads? To replace the front pads if you can remove the pins, remove the retainng clip and push back the cylinder can you just insert the new pads wihtout having to remove the calipers?
