2005 Other Isuzu Models Engine crankshaft bearing failure
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2005 Other Isuzu Models 4 cyl Two Wheel Drive Automatic 80,000 miles
my car break down due to a major failure in crankshaft bearing in piston 2 only, I would like to know what could be the causes for such cases?
Is it the oil pump or somthing else? Pls advise.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
