Engine Mechanical problem
2005 Hyundai Accent 4 cyl Front Wheel Drive Manual 50000 miles
My hyundai acccent one day decided to not start and i have a feeling it is my fuel pump. The reason i think it is the pump is, when you turn the key to the on postion you cannot hear the pump kick on. And when i try to start the car the starter just cranks away and the motor sounds as if it is not getting any gas. I was just going to try to replace the pump but I dont know where it is. I am hoping it is not inside the gas tank if you were able to tell me where the pump is located that would be a great help. thank you
Josh
Find a
repair manual for your Hyundai Accent Repair Question.
Posted at Fri Apr 18, 2008 1:38 pm
By
Advertisment,
Find a
Posted at Fri Apr 18, 2008 3:47 pm
By
blackop555,Certified 2CarPros Master Technician
the fuel pump is in the tank, but before you go and replace it, check for voltage at it while someoen turns the key to on, if it is geting voltage and no pump reponse, pump is bad.
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
