Free Auto Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2005 Ford Freestyle No Start
Posted at Tue Dec 16, 2008 5:33 pm |
By
Jiles,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
2005 Ford Freestyle 6 cyl All Wheel Drive Automatic 43000 miles
I am a retired auto mechanic. I have a fully serviced 05 Ford Freestyle with 43K. Had since nearly new with absolutely no problems. Wife pulled the vehicle out of the carport and parked it.
She asked me to pull car back in and it would not start.
The engine turns over and seems to be trying to start on less then all cylinders. It will hit on about 2 or 3 cylinders, run rough for less then two seconds and will go dead. Additional attempts result in exactly the same results.
My scanner shows no codes, I reset the fuel pump, tried the additional ignition key with no luck.
There is a strong smell of unburned or partually burned gasoline.
The car is outside and weather prevents me from checking anything now.
I seem to remember reading that an unprogrammed key or malfunctuning theft system would give these starting problems.
What are your thoughts conserning this problem?
THANKS |
Find a
car repair manual for your Ford Freestyle Repair Question.
Posted at Fri Feb 12, 2010 10:00 am |
By
hobodewey,
Likes to hang around! |
(16) Give Feedback | Votes: 0 |
| Jiles wrote: | Engine Performance problem
THANKS |
Ford is notorious for failed MAF sensor. Unplug the harnes from the sensor (located in the air filter box) and try to start. If it does start then replace the MAF sensor. Look on Ebay. They sell new ones for about half of the price that the auto parts stores charges for remanufactured ones. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
