Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2005 Ford Freestyle Abs and trac ctlr light on!
Posted at Thu Jan 15, 2009 4:39 am |
By
rlbatez,
New to the forum |
(12) Give Feedback | Votes: 0 |
Brakes problem
2005 Ford Freestyle 6 cyl All Wheel Drive Automatic 65000 miles
I replaced the Left rear hub assembly and now the abs and trac lights are on, There is an abs sensor connection underneath the hub and closer to the diff, but it looks untouched. I tried to take the sensor out to see if it was dirty but after removing the 8mm bolt i could not get the sensor out as it is plastic and i thought i might break it. Anyone know how the sensor is supposed to come out?
Thanks. |
Find a
car repair manual for your Ford Freestyle Repair Question.
Posted at Thu Jan 15, 2009 5:14 am |
By
Dave H,
Certified 2CarPros Technician |
           (5846) Give Feedback | Votes: 75 |
Wheel Speed Sensor - Rear, AWD
Removal and Installation
CAUTION:Make sure to correctly route and secure the wheel speed sensor harness in the rear subframe assembly.
All vehicles
With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to JACKING & LIFTING .
Disconnect the wheel speed sensor electrical connector.
Remove the wheel speed sensor bolt.
To install, tighten to 8 Nm (71 lb-in).
LH
Release the wheel speed sensor harness spring clip and the 2 pin-type retainers from the rear control arm.
Release the wheel speed sensor harness pin-type retainer and remove the wheel speed sensor.
RH
Release the 3 pin-type retainers and remove the wheel speed sensor.
All vehicles
To install, reverse the removal procedure.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
