Engine Mechanical problem
2005 Ford Expedition V8 Two Wheel Drive Automatic 59000 miles
Just the past week, I went to start and had an extended crank to start on warm restarts. It seemed okay cold. Took where I work, and found residual fuel pressure to drop quickly to zero. Replaced fuel pressure regulator, and still drops to zero but not as quick.
Find a
repair manual for your Ford Expedition Repair Question.
Posted at Thu May 01, 2008 2:01 pm
By
Advertisment,
Find a
Posted at Thu May 01, 2008 2:05 pm
By
merlin2021,Certified 2CarPros Master Technician
How long does it take? Try turning the key on and wait 2-3 seconds, then see if it starts. Some Fords, have a revised idle air control valve due to extended cranking time...can also be caused by a fault PCV...or vacuum leak.
Find a
It takes about 10 seconds to start-if I cycle the key then restart is almost normal. Also, if I turn the key on for about 2-3 seconds it starts fine.
After replacement of the fuel pressure regulator, it doesn't seem to take as long, but at times, still cranks maybe 5 seconds to start. Cold start up has now also been affected.
Find a
Posted at Thu May 01, 2008 2:23 pm
By
If you are looking for a OBDII I selling one on ebay called the autoxray code scout 1500. Highest bid so for is 99 cents. It was only used twice. Works great. Here is the link.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
