Drive Train Axles Bearings problem
2005 Dodge Ram 6 cyl Four Wheel Drive Manual
2005 Ram 3500 Series 4 WD, bought new, 77,000 miles. Drove fine then stopped at red light. Went to take off and the whole truck jumps so bad it makes your voice shake...even at 1 mph. When in neutral- truck is fine. Only vibrates when in drive mode. Jacked up truck and motor looks like out of balance washing machine, drive shaft is also affected. changed out carrier bearing--no change. can rev up vehicle in neutral and no vibration. u joints appear fine. removed clutch- all fine. any suggestions?
