Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2005 Dodge Ram V8 Two Wheel Drive Automatic 52000 miles
My truck will stall and shudder occasionally (3 out of 5 stops) when stopping while the engine is cold, but runs fine when the engine has been warmed up. I've read a lot of questions here and I've seen some of the solutions. Where I differ is I have changed my transmission fluid and filters about 2-3 weeks before this problem started occurring. I see that people have been able to solve similar problems by changing the IAC valve and the EGR valve, but I can't help but think it's related to my transmission fluid/filter change. Would something I've done incorrectly lead to this problem? Perhaps one of the filters I changed is faulty? Not seated correctly? The installation was a bit of a pain and I don't necessarily have all the confidence that its perfect. Should I explore the tranny issue more, or the emissions system issue?
I should also add that the CEL is NOT on and is not throwing any OBD codes.
** Adding more detail: I also want to add that there is no problem with the idle or stalling when the truck is not in gear. It only shudders and stalls when stopping or slowing (below 10mph). Also, I have taken the IAC valve off and cleaned it with gasoline as best I could but the problem persists.
I would ask if it seems to be transmission, or the engine that the shudder comes from? when it does it try putting the shifter into neutral, does the shudder stop? If so, recheck the work you did on the tranny, if the filter came out or is not seated in the o ring seal, you will have tranny problems, when it's cold, it may be looser than when warmed up. Heat expands all things!
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
