Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2005 Dodge Caravan will not start
Posted at Fri Nov 06, 2009 9:08 am |
By
jamesgrega,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2005 Dodge Caravan 6 cyl Automatic 89,000 miles
when I turn key al guages jump to complete foward position and the back to original setting engine does not turn over , noise like starter trying to engage. |
Find a
car repair manual for your Dodge Caravan Repair Question.
Posted at Fri Nov 06, 2009 9:24 am |
By
jdl123,
Moderator |
     (3072) Give Feedback | Votes: 92 |
Welcome to the forum, thanks for the donation, are you saying it cranks good but won't start, or the starter won't even crank? |
Find a
Posted at Sat Nov 07, 2009 9:47 pm |
By
jamesgrega,
Have Donated |
It will not turn over at all.
headlights work and interior lights working.
Instrument panel guages all move to max postion then come back to normal.
The speedometer indicator moves all the way to 120 the falls back to 0. Radio will not come on. |
Find a
Posted at Sun Nov 08, 2009 7:08 am |
By
jdl123,
Moderator |
i'd make sure the battery has a full charge and the connections are good. Next, I'd get at the starter relay, underhood, power distribution center/integrated power module. Check the relay circuits, voltage and ground.
Do you think the theft system may be causing a problem? My info says the first 6 attemps to start is fuel disable after that the starter won't even crank. You may need to check for codes. |
Find a
Posted at Sun Nov 08, 2009 11:26 am |
By
jamesgrega,
Have Donated |
I will check battery charge however the guages moving like they do when I turn the key, just to on not a full turn to start engine, the lights working interior and headlights and then no radio leads me to think electrical rather than a battery problem, I have not tried to jump it but plan to do that tomorrow.
I have only tried to get it to turn over maybe three or four times. I will loosen and tighten cables to the battery before I try jump jump just to be sure.
I think ground problem and do not know where to start with that. Where do I locate the relay you mentioned, on right or left side of engine?
Thanks |
Find a
Posted at Sun Nov 08, 2009 12:18 pm |
By
jdl123,
Moderator |
The integrated power module should be under the hood, driver side. The relay should be inside the box.
your probably right about electrical issue, I always start with basics.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
