Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Pontiac Grand Prix ...
Auto Repair1990 Oldsmobile 98 Cold...
Auto Repair1988 Chevy Blazer Truck...
Auto Repair1998 Ford F150 Airbag W...
Auto Repair1995 Toyota Corolla Rev...
Auto Repair2001 Dodge Ram Heater Core
Auto Repair1994 Jeep Yj Key Igniti...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2005 Chrysler Town and Country clunking noise front suspens
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Apr 05, 2008 8:34 am
By fn19, New to the forum
Give Feedback | Votes: 0
Suspension problem
2005 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic 54000 miles
I hear a "clunking" noise when I go over bumps while driving, which seem to be coming from the right front end. I have inspected the ball joint and sway bar bushings and both seem to be ok. I cannot visualize anything obvious. It was reported that there was an "oil" leak near the right front tire. I do not see that now. I am thinking it may be a problem with the strut.
Any thoughts?
Thanks, Bill
Find a car repair manual for your Chrysler Town and Country Repair Question.
Posted at Sat Apr 12, 2008 7:24 am
By laa, New to the forum
I too need help with this question. Front end noise when driving on uneven surfaces, Sounds are clanking, metal hitting metal, something loose needs tightening or about to fall off. It sounds as if it is on the drivers side. Can sometimes feel slight vibration on foot when the rattling noise happens. It used to be worse only in the cold winter months but not it does this all the time while driving on uneven surfaces. Took vehicle to mechanic and they didn't have a clue. Troubleshooted saying that is was possible the front struts at over $200 to replace. I said that wasn't it but my husband and mechnic said it might be. Both inspected everything in front end and did not find anything loose. I told them it sounded more on the drivers side. Decided to replace strut passenger side only, wouldn't listen to me. I said that it was not the strut because van drives smooth on even road surfaces suchas highway. Goes over railroad tracks with out problems. No bouncing, no feeling in steering wheel, no squeeking, etc. After "repair" I drove out of the garage less over $200 in my pocket and immediately the noise returned.
Please someone reply, as Im about to drive this van over a cliff. Could it possibly be rubber bushings, rods. If so how to know which?
Posted at Mon Apr 14, 2008 7:25 am
By Scottjay, Likes cars!
I have a 2003 T&C and had the same problem. I found it to be the front sway bar bushings. When they wear out there is less space between the sway bar and the frame. They only cost about $20 and if you are fairly mechanical, you can replace them yourself. Just put the front end up on jack stands to take the stress off the sway bar. There are two bolts that hold the bushings in place. Remove them and replace the bushings. They can be a pain to remove but be patient and you will be surprised at how little it cost to get rid of that annoying "clunk".
Posted at Wed Apr 16, 2008 4:45 pm
By GeoffB, New to the forum
I have a 2005 T & C with 125K miles. Runs really sweet with the exception of the dreaded clonking noise. It's had it for thre last 20k miles. Every oil change, I asked the mechanics to make sure everything is tight. Yesterday I paid $400 for two new struts (needed the struts but it didin't cure the noise). Tomorrow I will replace the sway bar bushings and let you know. You feel as though sometrhing is about to break or drop off. Very worrying. I have checked everything that looks as though it could flap or knock - keeping my fingers crossed that its the bushings. UPDATE: Mechanic refused to change bushings after another inspection. Is there enough play in a worn bushing to be felt by hand>
Posted at Fri Apr 18, 2008 11:15 am
GeoffB
Do you know if the sway bar bushings have ever been replaced? If they are the originals, then given the mileage you stated at 125K, I'd say they are in need of replacement. I'm surprised your mechanic refused to replace them. Since when does a mechanic refuse work? Unless you're strong enough to make the sway bar hit the frame, there would be no way to test if the bushings are worn enough to make the clunking noise but for the price of the bushings being around $20, why not change them out? If you look closely at just how little space there is between the sway bar and frame; maybe an inch or so; it doesn't take a trained mechanic to see that's where the noise would be coming from.
Posted at Mon Jul 21, 2008 4:27 pm
By ubergeeken, New to the forum
Had a similar experience - here is what happened:
Driving would be fine until I moved forward from a stopped position. The front driver side would make an aweful creeking and clunking noise. I feared that it was transmission tralated based on when it would make the noise.
It turned out that the lower control arm of the driver side suspension was going bad. The bolt that passes through the control arm that holds it to the lower portion of the car supension was ground down. The bolt was literally being eaten inside the hole it passed through to hold the lower control arm to the car.
They replaced the lower control arm and the bolts and all was good.
Acording to the dealer, this is something that is common on cars above 120k miles. Mine is only 70k and it was 62k when the propblem ocured.
They isolated the issue by using "electronic ears" to help them find where the noise was really coming from. Without them it's almost impossible to find those type of noises since they only ocure under normal operation - not while suspended in the air on a rack.
Greg
Posted at Wed Jul 23, 2008 7:17 pm
By 2003T&CEX, Likes cars!
my money is on the Sway bar links
My 2003 T&C have been replaced at 30,000 at 60,000 and at 95,000 all with the same clunking noise and it fixed it each time
Cheap and fairly easy repair
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
