Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2005 Chevy Equinox CD STUCK IN AC DELCO PLAYER
Posted at Tue Jan 29, 2008 5:30 am |
By
clebo1,
New to the forum |
Give Feedback | Votes: 0 |
Other Category problem
2005 Chevy Equinox 6 cyl All Wheel Drive Automatic 44300 miles
PLEASE NOTE i HAVE A GOOD CD STUCK IN A AC EELCO PLAYER,WILL NOT EJECT,AND GIVE ERROR MESSAGE WHEN YOU TRY TO DO SO AS NO CD AND THEN CHECK CD,THIS IS A 1 1 CD UNIT PLAYER,CD WILL WILL BUT WILL NOT EJECT.I HAVE ASK MY BADWRENCH AND OTHER CHEVY OUTLETS SUCK AS GM,THE CHEVY CAC-CUSTOMER SERVICE WHO ARE ATROCIOUS AND VEN I ASKED THE mfg AC DELCO,NONE OF THESE CHEVY-GM ENTITIES HAVE NOT GOTTEN BACK TO ME WITH A RESPONSE,CAN YOU HELP???THANK YOU.. |
Find a
car repair manual for your Chevy Equinox Repair Question.
Posted at Tue Jan 29, 2008 5:32 am |
By
clebo1,
New to the forum |
| clebo1 wrote: | Other Category problem
PLEASE NOTE i HAVE A GOOD CD STUCK IN A AC EELCO PLAYER,WILL NOT EJECT,AND GIVE ERROR MESSAGE WHEN YOU TRY TO DO SO AS NO CD AND THEN CHECK CD,THIS IS A 1 1 CD UNIT PLAYER,CD WILL WILL BUT WILL NOT EJECT.I HAVE ASK MY BADWRENCH AND OTHER CHEVY OUTLETS SUCK AS GM,THE CHEVY CAC-CUSTOMER SERVICE WHO ARE ATROCIOUS AND VEN I ASKED THE mfg AC DELCO,NONE OF THESE CHEVY-GM ENTITIES HAVE NOT GOTTEN BACK TO ME WITH A RESPONSE,CAN YOU HELP???THANK YOU.. | |
Find a
Posted at Thu Jan 31, 2008 6:50 pm |
By
dennyp,
Certified 2CarPros Technician |
(245) Give Feedback | Votes: 6 |
You will have to replace the CD player or send it in to an AC Delco authorized repair center. |
Find a
Posted at Tue Feb 19, 2008 8:26 pm |
By
mdbeachy,
New to the forum |
Try pulling the fuse out to let the system reset itself. Mine had the same problem, after I pulled the fuse it reset and I was able to eject the cd's and it has been working fine. |
Find a
Posted at Fri May 30, 2008 3:11 pm |
By
magicv8,
New to the forum |
Pulling the fuse worked for me. While it was out I vacuumed out the cd slot, blew in compressed air, vacuumed again and when I put in a fuse IT ALL WORKS AGAIN.
The down side is that while I was trying to replace the fuse in its RH console cubby hole I dropped it (into a black hole?) and had to go buy fuses. |
Find a
Posted at Fri May 30, 2008 8:42 pm |
By
dennyp,
pulling the fuse is usually only a temporary fix. However, if you got enough dirt out of it, it might be fixed. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
