Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
2005 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 89,000 miles
Temp gauge goes from cool all the way over past the red mark - even when engine is cold. Does not run hot, no odors, etc.
Unplug the wire from the temp sensor on the end of the cylinder head above the bellhousing (trans). If the guage stays on cold or doesn't move, replace the sensor (about 12 bucks). If it does the same thing then there is a short in the wiring probably in the sensor connector or look for frayed wires.
Donate if this solves your problem as they solved mine so I donated and now I also try to help when I can. VIC
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
