2005 Buick La Crosse
Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Car Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Auto Parts
Vehicle Repair Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Jeep Wrangler 2001...
Auto Repair1984 Ford F350 Feels Li...
Auto Repair1998 Nissan Altima Car ...
Auto Repair1995 Toyota Camry Engin...
Auto Repair1995 Ford Ranger 1995 F...
Auto Repair2002 Dodge Stratus Wind...
Auto Repair1999 Buick Park Avenue ...
Auto Repair1985 Mazda Rx7 Carb/fue...
Auto Repair1996 Chevy Truck
Auto Repair2004 Dodge Caravan Star...
Auto Repair1998 Ford Explorer
Auto Repair1996 Toyota Avalon
Auto Repair1995 Isuzu Rodeo Questio...
Auto Repair2006 Chevy Silverado
Auto Repair2002 Buick Lesabre
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Other Websites
Auto Repair Computer Repair Questions
Auto Repair Search Engine Optimization
Auto Repair WhyOurWorld.com
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Welcome to our question and answer forum were over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri Jan 11, 2008 10:06 am
By 1nomad, New to the forum
Give Feedback | Votes: 0
Suspension problem
2005 Buick La Crosse V8 Front Wheel Drive 28000 miles
How to replace lower control arm
Find a repair manual for your Buick La Crosse Repair Question.
By Advertisment,
Posted at Sat Jan 12, 2008 12:08 pm
By dennyp, Tech level 7
Reputation: 96.3Reputation: 96.3Reputation: 96.3Reputation: 96.3Reputation: 96.3 (96) Give Feedback | Votes: 5
Lower Control Arm Replacement
Tools Required
J 41820 Ball Joint/Stud Separator
Removal Procedure
Notice: Use only the recommended tools for separating the ball joint from the knuckle. Do NOT hammer or pry the ball joint from the knuckle. Failure to use the recommended tools may cause damage to the ball joint and seal.
Important: Use the ignition key in order to unlock the steering column.
Turn the steering wheel in order to move the front of the applicable wheel to the outboard most position.
Important: Use ONLY a frame-contact type vehicle lift or a floor jack at the recommended lift points. Do NOT use a suspension-contact type vehicle lift. Do NOT lift the vehicle by the lower control arms.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the tire and wheel. Refer to Tire and Wheel Removal and Installation .
If applicable, disconnect the ABS wheel speed sensor connector.
If applicable, disconnect the ABS wheel speed sensor jumper harness from the harness retainer clips.
Remove the cotter pin (1) from the ball stud (3).
Loosen the ball stud nut (2).
Install the J 41820 over the ball stud and lower control arm as shown.
Rotate the ball stud nut counterclockwise in order to separate the ball stud from the steering knuckle.
Remove the J 41820 .
Remove the ball stud nut.
Remove the lower control arm bolts and nuts.
Remove the lower control arm.
Installation Procedure
Install the lower control arm.
Install the control arm bolts and nuts. Do not tighten at this time.
Important: Align the ball stud cotter pin hole parallel to the knuckle in order to ease the cotter pin installation.
Install the ball stud to the knuckle.
Notice: Refer to Fastener Notice in Cautions and Notices.
Install the ball stud castle nut.
Tighten
Tighten the nut to 20 N·m plus 120 degrees (15 lb ft plus 120 degrees).
Important: Do NOT loosen the ball stud nut in order to align the ball stud nut slots to the ball stud cotter pin hole.
If necessary, tighten the ball stud castle nut in order to align the ball stud castle nut slot (1) to the ball stud cotter pin hole (2) as shown.
Important: If applicable, ensure that the cotter pin ends do NOT contact the ABS wheel speed sensor, the ABS sensor connector or the drive axle.
Install a NEW cotter pin and bend the ends as shown in either example.
If applicable, connect the ABS wheel speed sensor jumper harness to the harness retainer clips.
If applicable, connect the ABS wheel speed sensor connector.
Important: This is a prevailing torque type fastener. This fastener may be reused ONLY if:
• The fastener and its counterpart are clean and free from rust.
• The fastener develops 3 N·m (27 lb in) of torque against its counterpart prior to the fastener seating.
If the fastener does not meet these criteria, REPLACE the fastener.
Install the lower control arm nuts.
Tighten
Tighten the lower control arm nuts to 125 N·m (92 lb ft).
Install the tire and wheel. Refer to Tire and Wheel Removal and Installation .
Lower the vehicle.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
