Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Ford Taurus
Auto Repair1993 Oldsmobile Cutlass ...
Auto Repair1993 Geo Metro Oxygen S...
Auto Repair2003 Ford Ranger
Auto Repair1996 Toyota Rav4
Auto Repair2006 Mercury Mariner Ta...
Auto Repair1990 Chevy Silverado Ma...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2005 Buick La Crosse Fan keeps running
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon May 26, 2008 9:23 am
By chuckbuick, New to the forum
Give Feedback | Votes: 0
Air Conditioning problem
2005 Buick La Crosse 6 cyl Front Wheel Drive Automatic 11,000 miles
The fan for the AC and heated were not working. I checked the fuses and found that one of the fuses for the fan was bad. I replaced the fuse and the fan motor kicked right on. I checked the AC and it was working fine now at all speeds.. Great right? .. Wrong, the fan continued to run even after I turned the car completey off killing my battery. Any suggestions as to where to start?
Find a car repair manual for your Buick La Crosse Repair Question.
Posted at Mon May 26, 2008 4:18 pm
By brian 1, Tech level 3
Reputation: 22.6 (23) Give Feedback | Votes: 1
you have to install a capacitor.here is a bulletin.Subject: Blower Motor Inoperative or Intermittent, Blower Speed May Drop or Blower Continues to Run After Key Off (Install a Capacitor at Blower Motor Control Module Connector)
Models: 2005 Buick Allure (Canada Only), LaCrosse
2004-2005 Pontiac Grand Prix Some customers may comment on an inoperative or intermittent Heating, Ventilation and Air Conditioning (HVAC) blower motor. Others may comment that the blower motor speed may momentarily drop or that the blower motor continues to run after the key is turned off.
Disconnect the negative cable from the battery. Refer to the Battery Negative Cable Disconnect/Connect procedure in the Engine Electrical section of SI.
Remove the right closeout/insulator panel. Refer to the Closeout/Insulator Panel Replacement-Right procedure in the Instrument Panel, Gages and Console section of SI.
Disconnect the wire harness connector to the blower motor control module. start here
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
