Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
2005 Acura RSX 4 cyl Front Wheel Drive Manual 79000 miles
i broke a plastic shifter componant next to the shift assembly!!! it holds the far left cable in and without it i only had 3rd and 4th gear. it had a spring on it as well. i would normally have 1-6 and revears. i wanted to know what it was called and about how much it would cost. thanks.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
