Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Pontiac Firebird F...
Auto Repair1995 Toyota Celica 95 C...
Auto Repair2002 Volkswagen Jetta C...
Auto Repair2002 Ford Ranger Altern...
Auto Repair1997 Ford F150 Importan
Auto Repair1984 Oldsmobile Cutlass ...
Auto Repair1994 Jeep Cherokee Erra...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2005 Acura MDX
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 26, 2008 6:21 pm
By Lori1770, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
2005 Acura MDX 6 cyl Four Wheel Drive Automatic 19,350 miles
Had car back at dealer 3 times to fix air conditioning problem. 1st time they thought i might be leaking refrigerant and added some. 2nd time found nothing wrong even though I was complaining car was not getting cool enough. 3rd time, air conditioner was only blowing hot air. At this time they replaced the compressor and clutch. Working fine for about 2 days now, finding that car again not getting cool enough, but noticed that it is happening mostly when car is idling in traffic. Once I accelerate, car is starting to get cool again, but not as cool as it should be. I have the temp. turned lower than 60. At that point it should be freezing and it is just comfortable. I also noticed that if I press slightly on the automatic window buttons on the driver side door, the air speed changes slightly.
Find a car repair manual for your Acura MDX Repair Question.
Posted at Sun Jul 27, 2008 3:34 am
By mastertechtim, Moderator
Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4Reputation: 302.4 (302) Give Feedback | Votes: 20
this is very easy. first clue is that it get cooler when moving. this tells me either the cooling fan is not coming on when ac is on causing no air flow through the condenser and when you start driving the air is now being circulated through it cooling it down. basically there is a mini radiator in front of the engine radiator that the ac uses to make the freon turn from a liquid into a gas, it needs to be cooled in order to accomplish this. if this is not the case, (im confident it is) then the system is low on freon again from a leak, (probably not). do me a favor and repost what you find so we can all learn, thanks for using 2 carpros.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
