Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Toyota Sienna Rotor Replacement
Posted at Sat Oct 10, 2009 10:36 am |
By
lbc2791,
Have Donated |
Give Feedback | Votes: 0 |
Brakes problem
2004 Toyota Sienna 6 cyl Front Wheel Drive Automatic 96000 miles
How do I remove the rotor? I removed the tire, brake pads, califer, th.e only thing left is the rotor but it is tight |
Find a
car repair manual for your Toyota Sienna Repair Question.
Posted at Sat Oct 10, 2009 10:48 am |
By
obxautomedic,
Certified 2CarPros Technician |
  (1373) Give Feedback | Votes: 43 |
Look arounf the lug studs, if they are original rotors most have a retaining Spring on 2 of the Studs.
If no retaining springs look around face of rotor for 2 maybe 3 Philips Head Screws, they will need to be removed in order to remove rotors.
If neither of the above spray around center hub and with hammer strike the face of the rotor in different areas. Make take some good hard strikes to break the rust loose.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
