Auto Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Toyota Sienna Fan
Posted at Thu Oct 29, 2009 7:35 pm |
By
eringlasenapp,
Have Donated |
Give Feedback | Votes: 0 |
Noises problem
2004 Toyota Sienna All Wheel Drive Automatic 81,000 miles
It is cold here today. I drove home (about a mile) and the fan on my van won't turn off. It's been almost an hour. What should I do? |
Find a
car repair manual for your Toyota Sienna Repair Question.
Posted at Thu Oct 29, 2009 11:58 pm |
By
merlin2021,
Certified 2CarPros Master Technician |
                    (10320) Give Feedback | Votes: 136 |
Check the fan relay(s) under the hood in the power distribution center. And the fan switch on the engine block.
COOLING FAN RELAY Cooling Fan Relay 1. Disconnect negative battery cable. Remove cooling fan relay from fuse/relay box. See COMPONENT LOCATIONS . Using an ohmmeter, check for continuity between relay terminals No. 1 and 2. See Fig. 3 . If no continuity exists, replace relay. Using an ohmmeter, check for continuity between relay terminals No. 3 and 5. See Fig. 3 . If continuity exists, replace relay. 2. To check relay operation, connect positive battery voltage to terminal No. 1 and ground to terminal No. 2. Check that continuity exists between relay terminals No. 3 and 5. If no continuity exists, replace relay. Reinstall cooling fan relay. Fig. 3: Identifying Terminals Of Cooling Fan Relays Courtesy of TOYOTA MOTOR SALES, U.S.A., INC. ENGINE COOLANT TEMPERATURE SENSOR 1. Drain engine coolant. Remove ECT sensor. See ECT SENSOR LOCATIONS . Place ECT sensor and thermometer into a water bath. ECT SENSOR LOCATIONS 2. Measure resistance between terminal Nos. 1 and 2. See Fig. 4 . If resistance is not as specified, replace ECT sensor. 3. Install NEW gasket on sensor, and install ECT sensor. Fill with engine coolant. Application Sensor Location Sienna On Water Outlet, Top Right Front Of Engine.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
