Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 12,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Suzuki Aerio Crank Angle Sensor
Posted at Wed Apr 16, 2008 6:19 pm |
By
EmeraldSage,
New 2Carpros Member |
Give Feedback | Votes: 0 |
Computer problem
2004 Suzuki Aerio 4 cyl Two Wheel Drive Automatic 30K miles
It seems I need to replace the crank angle sensor, and I have gotten jerked around a lot by 2 dealerships and an independent repair shop (quotes jumping around, differing information). Really all I want to know is how difficult of a repair is it. I've been told its under the spark plug, behind the transmission, and various other locations.
I can get the part for about $200 online, they want to charge 350 plus labor which goes to around $500-700 is that reasonable? |
| Find out more about your Suzuki Aerio Repair Question: NEED MORE
TECHNICAL INFO? Car Repair
Manual - Questions by Topic -
First Things to Check - How to Car Repair - How Does it Work?
- Donate Here |
Posted at Sun Nov 08, 2009 8:13 pm |
By
Dave H,
Certified ASE Technician |
(30) Give Feedback | Votes: 105 |
Crankshaft Position (CKP) Sensor Removal and Installation
Removal
Remove engine with transmission from vehicle referring to ENGINE ASSEMBLY REMOVAL AND INSTALLATION .
Remove transmission from engine and then remove flywheel or drive plate from crankshaft.
Disconnect connector from crankshaft position sensor.
Remove crankshaft position sensor (1) from cylinder block (2).
Installation
Reverse removal procedure noting the following.
Check to make sure that crankshaft position sensor (1) is free from any metal particles and damage.
Apply engine oil to O-ring of sensor.
Install crankshaft position sensor to cylinder block (2) with specified torque.
Tightening torque
Crankshaft position sensor bolt (a): 6 N.m (0.6 kg-m, 4.5 Lb-ft)
Fig. 28: Installing Crankshaft Position Sensor To Cylinder Block
Courtesy of SUZUKI OF AMERICA CORP.
Connect connector and fix wire harness with clamp securely. |
- Donate Here |
Make a small donation! (We will make
sure your question will be answered promptly)
