dawrob
I don't know if you already had your Xterra leakage problem fixed. I have the same year and model Xterra but with about 57,000. On my Xterra there was some signs of anti-freeze around the neck of bypass hose connector to the manifold. The mechanic told me replacing the bypass hose will be $310 but he does not believe the leak is bad enough to do that. He said just to keep an eye on the anti-freeze level making sure it stays normal level. I believe your problem was similar but the pressure testing damaged your manifold gasket, thermostat housing gasket, thermostat, and bypass hose connection. If your engine needed a new knock sensor it should have registered as an engine error code when the SERVICE ENGINE SOON light came on.
