Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Chrysler Sebring T...
Auto Repair1999 Bmw 328 Noise From...
Auto Repair1998 Chevy Truck Water ...
Auto Repair1988 Dodge Truck
Auto Repair1997 Ford F150 4x4 Not ...
Auto Repair1987 Chevy Camaro Dash ...
Auto Repair2000 Chevy Silverado St...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2004 Kia Optima Trying to overheat
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri May 23, 2008 3:21 pm
By staci price, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
2004 Kia Optima 4 cyl Two Wheel Drive Manual 83,200 miles
My car keeps trying to overheat. It never has but it gets almost in the red everyday. When I turn off the AC it will go down a little...but it is hot in Louisiana and I need my AC. The AC does work fine, it just makes my car to run hot.
Find a car repair manual for your Kia Optima Repair Question.
Posted at Sat May 24, 2008 2:25 am
By mhpautos, Certified 2CarPros Master Technician
Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5Reputation: 515.5 (516) Give Feedback | Votes: 11
Hi there,
Time for a full cooling system service. Replace the thermostat, have the radiator cleaned & flow tested, check the pressure cap & flush the old coolant. Make sure that the fans are working (two) with the A/C on as well.
Mark (mhpautos)
Posted at Wed Jun 25, 2008 2:32 pm
By dougsego, Likes cars!
It sounds as if we have virtually the same problem: almost overheating 80K 2004 Optima with ac on. I've tried almost everything: new water-pump, new thermostat, radiator flush, verified hoses not collapsing, verifiying both fans operational. I'm going to lean-out the anti-freeze from 50% to the 35% minimum recommended and see if that works. Please post to your site if you find anything. Thanks. Doug
Posted at Mon Jul 14, 2008 7:20 am
I had an intermittant indication of overheating with my Optima. I tried everything to isolate the problem: new water-pump, new thermostat, radiator flush. However, when the needle approached red, and I turned off and turned on the engine again, it would show normal. This turned out to be an electrical problem, and was eventually isolated to (you're not going to believe this) A LOOSE NEGATIVE BATTERY CABLE!
Posted at Mon Jul 14, 2008 2:15 pm
Hi dougesego,
Thanks for the in put. it all helps. This is a good example of looking at all the possibilities and keeping on top of basic maintaince issues, modern cars and the electrical systems are a pain at the best of times, but a simple problem as a loose or dirty terminal can sure through a spanner in the works.
Mark (mhpautos)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
