Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Infiniti G35 Slippage
Posted at Tue Jan 19, 2010 7:25 pm |
By
milesdad28,
Have Donated |
Give Feedback | Votes: 0 |
Transmission problem
2004 Infiniti G35 6 cyl Two Wheel Drive Automatic 103000 miles
I just learned that the wrong transmission fluid was added to my Infiniti g-35 about 25,000 miles ago. I'm now experiencing transmission slippage when accelerating. do you think the wrong fluid could have been the cause of it? If so, could it be fixed by draining the fluid and replacing with the correct fluid? Would the wrong fluid cause long term damage that is not repairable? Any other guess why my transmission would start slipping after only 100,000 miles? thanks for your help |
Find a
car repair manual for your Infiniti G35 Repair Question.
Posted at Wed Jan 20, 2010 5:51 am |
By
2CarPros Jack,
Certified ASE Technician |
                       (11840) Give Feedback | Votes: 111 |
Those arent the most reliable transmissions to begin with, so 100k isnt as bad as you may think.HAving the entire system flushed with Nissan fluid could help, but no guarantees.The incorrect fluid can cause damage to internal seals, clutch plates, basically any wearing item in the trans could be affected by the wrong fluid. All damage is repairable, you may be looking at a rebuild if it is slipping and has that many miles on it, I would stick with Nissan on this, have seen many trans problems from independent shops with Nissan products |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
