Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Hyundai Sonata ELECTRICAL PROBLEM
Posted at Sat Nov 07, 2009 8:31 am |
By
aawilliams,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
2004 Hyundai Sonata 6 cyl Two Wheel Drive Automatic 103000 miles
WHENEVER I PRESS THE BRAKE PEDAL, MY DASH LIGHTS COME ON, WHEN I RELEASE THE BRAKE PEDAL, THEY GO OFF. ALSO, WHEN I TURN THE HEADLIGHT ON, THE BRAKE LIGHT THAT IS ABOVE THE TRUNK COMES ON. DOES ANYONE KNOW HOW TO FIX THIS PROBLEM? |
Find a
car repair manual for your Hyundai Sonata Repair Question.
Posted at Sat Nov 07, 2009 9:42 am |
By
KHLow2008,
Certified 2CarPros Technician |
         (5167) Give Feedback | Votes: 69 |
Hi aawilliams,
Thank you for the donation.
Symptoms indicates a possible bad ground connection for the rear ligghts in trunk.
Check the ground connections at left rear of luggage compartment under trim panel.
Was any repairs carried out or damages to body parts prior to this occurring? |
Find a
Posted at Sat Nov 07, 2009 3:17 pm |
By
aawilliams,
Have Donated |
No repairs, only a new battery installed and brakes lights were changed because they went out. |
Find a
Posted at Sat Nov 07, 2009 6:53 pm |
By
KHLow2008,
The taillights and brake lights share a common ground and uses the same bulb with different circuit. If the ground is bad, any power from the brake circuit would not ba able to ground and the current would be drawn to the next ground of the lighting circuit thus causing the two circuits to be combined. Likewise operating the lighting causes the same conditions.
Recheck the brake lights that were replaced. Try unplugging each bulb and retest. There is a possibility the bulb replaced was not seated correctly. Check the bulb seats for crossed installation ( pluggin bulbs with hook type contacts tends to have the seats goout os position causing the problem if not correctly installed. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
