Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1990 Buick Lesabre Loos...
Auto Repair2000 Ford Windstar 2000...
Auto Repair1988 Chevy Suburban Won...
Auto Repair2004 Mazda 3 Steering, ...
Auto Repair1991 Pontiac Sunbird He...
Auto Repair1997 Ford Taurus Heat
Auto Repair1998 Pontiac Transport ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2004 Ford Taurus
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Fri Aug 29, 2008 7:32 pm
By dinomom66, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
2004 Ford Taurus 6 cyl Front Wheel Drive Automatic
My daughters 2004 Ford Taurus had been having a decrease in power. It died on her and my husband replaced the alternator. It was clear that it was bad. It is still not running well. When you start it up and riv it some then it dies when you let off the gas. if you get it on the road it runs fine, but when you stop and it will die. It will idle but if you riv it up much or put it in gear then it dies. PLEASE help. She needs her car to get to college and back.
Find a car repair manual for your Ford Taurus Repair Question.
Posted at Sat Aug 30, 2008 4:47 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7 (684) Give Feedback | Votes: 80
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle.
Posted at Thu Sep 04, 2008 4:59 pm
We replaced the alternator, then it would start but not idle unless you kept it reved up but then it would die after you let off the gas. We replaced the IAC like suggested. Now it will idle a little but still dies. The air conditioner compressor is making a noise and is going out as well. Need help in what to do next!
Posted at Fri Sep 05, 2008 4:30 am
I suggested cleaning it out, not replacing it.Is the check engine light on? If so have it scanned for codes, this may help figure out what is wrong. Also look for vacuum leaks, they will affect the idle and power
Posted at Wed Sep 10, 2008 3:14 am
Thank you for all the help. We let it run awhile and it is now idling but not as high as it should. Will this get better with driving it or is ther something else we should do? We know the air conditioner compressor motor is also going out and that makes it sound bad as well. Should we just try running it, I dont want to mess anything up. Thank you in advance...........
Posted at Wed Sep 10, 2008 4:52 am
Clean out the throttle bore as well.that will also stabilize idle. Does the car have a tachometer? if so what rpm is it idling at? If the a/c compressor is noisy, you shouldnt use it, as it may be contaminating the system with metal debris, unless it is just the bearing.If it is the bearing, then you need to have it replaced or the belt will fail due to misalignment of the pulleys and that will cause the engine to overheat. Is it always noisy or just with a/c on? if always it is probably the bearing, if only a/c then it is the compressor
Posted at Tue Sep 16, 2008 7:52 pm
It is noisy all the time. But we found out part of the problem is that it is blowing the A/C clutch relay, PCM keep alive power fuse. Do you think we should replace the compressor or could it be just the bearing? We appreciate all the help!!
Posted at Tue Sep 16, 2008 8:02 pm
If we do replace the compressor, do we also have to replace the accumulator or anything else?
Posted at Wed Sep 17, 2008 4:50 am
Takes alot of special pullers to do just the clutch and bearing.I would probably do the entire compressor.Yes you should replace the accumulator/ receiver dryer as well.
Posted at Thu Oct 02, 2008 4:24 pm
Okay, we replaced the A/C compressor and the accumulator. We were also told to replace the orfice tube but I can't find where it goes. Please tell me where to find it and how to replace it.. I think we are almost done! Thank you for all the help.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
