2004 Ford Explorer ABS light and 4x4High light flashes
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
2004 Ford Explorer V8 Four Wheel Drive Automatic 88,000 miles
I just replaced the HUB assembly in both front wheels...one about 3 months ago - and the other last week - since than the ABS light is on and the 4x4HIGH light flashes (8 flashes) - we replaced the censor on the transfer case - per a dealership and the light is still on....while driving you can also feel it skip when the light is on. Also when making a sharp turn you can feel and hear grinding in the wheels....which never happened until again the lights have been on...HELP i'm at my wits on to fix this.....any suggestions??
I jaust had the same problem where the ABS light is on & the 4x4 flashes intermittently.
I had the rear ABS sensor replaced and that fixed all the problems you mentioned. There is only one for the rear
You also have two ABS sensors on each front wheel they are on the inside of the rotor. You have to remove the rotor to remove the sensor. They come with a wire and cost about $130.00 each. Good luck.
I forgot one mention one thing, my mechanic told that he had download the code to reset the ABS light. It does not go out by itself, you could try disconnecting the battery for about 15 minutes and see if that resets the light, but then you have drive the car so it re-learns itself. See the manual for the procedure.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
