Posted at Fri May 16, 2008 6:48 pm |
By
RAINWIZARD8,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
2004 Dodge Stratus 6 cyl Front Wheel Drive Automatic 150,32 miles
CHECK ENGINE LIGHT CAME ON, AND CAR STARTED RUNNING ROUGH, SO HAD IT SCANNED AND GOT CODE P0108. IT SUGGESTED THAT IT MAY BE THE MAP SENSOR, HOW CAN I CHECK FOR SURE TO SEE IF THAT SENSOR IS BAD??? I TOOK OFF THAT SENSOR CLEANED IT AND CHECKED ALL HOSES, IS THERE ANYTHING ELSE I MIGHT TRY TO SOLVE THE PROBLEM??? CAR WHEN FIRST STARTED PUTTERS LIKE IT ISN'T GETTING GAS AND SOMETIMES TAKES A FEW TIMES TO START. IT SAYS VOLTAGE TO MAP IS TO HIGH
| Find a
repair manual for your Dodge Stratus Repair Question. |
By
Advertisment,
| Find a
Posted at Sat May 17, 2008 6:51 am |
By
RAINWIZARD8,
Have Donated |
HOW CAN I TELL WHICH PLUG MAY BE MISFIRING
| Find a
Posted at Sat May 17, 2008 1:54 pm |
By
RAINWIZARD8,
Have Donated |
THERE IS A SENSOR LOCATED RIGHT BELOW THE THROTTLE POSISTION SENSOR, I TOOK IT OFF TO CHECK IT OUT AND THE TIP ALONG WITH A SPRING FELL RIGHT OFF, SO I TOOK IT OUT CLEANED IT AND PUT IT BACK ON, WHEN I DID THE CAR WOULDN'T START AT ALL, SO I REMOVED IT ONCE AGAIN AND ADJUSTED IT A LITTLE AND THE CAR STARTED, BUT STILL NOT RUNNING RIGHT. IS THAT SOMETHING THAT MIGHT EFFECT THE AIR FLOW OR EVEN FUEL FLOW???
| Find a
Posted at Sat May 17, 2008 3:43 pm |
By
RAINWIZARD8,
Have Donated |
SO WHAT I'M ASKING COULD THAT CAUSE MY JERKING, AND IDLE PROBLEMS, ALSO COULD THAT BE THE REASON MY LIGHT IS ON AND I GOT THE P0108 COMPUTER CODE????
| Find a
Posted at Sun May 18, 2008 9:13 am |
By
RAINWIZARD8,
Have Donated |
I HAD MY CAR CHECKED TO SEE IF IT WAS MISFIRING AND THE COMPUTER SHOWED NOTHING, AS FAR AS MISFIRE, SO ANYMOREM IDEAS WHERE TO CHECK. NOTHING ELSE SHOWED UP WRONG WITH THE OTHER IGNITION PARTS HE CHECKED. I SAID THE CAR WAS JERKING SO LET ME DESCRIBE WHAT IT'S ACRUALLY DOING. WHEN I GO TO HIT THE GAS IT ACTS LIKE IT DON'T WANT TO GO, SO I RELEASE THE GAS AND HIT IT AGAIN, AFTER A COUPLE OF TIMES IT WILL FINALLY GET GAS AND GO. ALSO THE FIRST TIME I TRY TO START IT IT WILL DIE IMMEDIATELY, BUT I CAN TURN THE KEY AGAIN IMMEDIATELY AND IT WILL START. SO ANY MORE SUGGESTIONS AS FAR AS WHERE TO LOOK, SINCE NOTHING IN THE IGNITION SYSTEM IS SHOWING UP???? I APPRECIATE ALL OF YOUR HELP I REALLY DO.....
| Find a
Posted at Sun May 18, 2008 9:48 am |
By
obxautomedic,
Moderator |
 (38) Give Feedback | Votes: 4 |
| RAINWIZARD8 wrote: | | THERE IS A SENSOR LOCATED RIGHT BELOW THE THROTTLE POSISTION SENSOR, I TOOK IT OFF TO CHECK IT OUT AND THE TIP ALONG WITH A SPRING FELL RIGHT OFF, SO I TOOK IT OUT CLEANED IT AND PUT IT BACK ON, WHEN I DID THE CAR WOULDN'T START AT ALL, SO I REMOVED IT ONCE AGAIN AND ADJUSTED IT A LITTLE AND THE CAR STARTED, BUT STILL NOT RUNNING RIGHT. IS THAT SOMETHING THAT MIGHT EFFECT THE AIR FLOW OR EVEN FUEL FLOW??? |
I would replace that sensor. He's right is should not fall apart.
| Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
