Car Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2004 Dodge Neon
Posted at Thu Nov 19, 2009 12:44 am |
By
jason2004neon,
Likes to hang around! |
Give Feedback | Votes: 0 |
Noises problem
2004 Dodge Neon 4 cyl Front Wheel Drive Automatic 85000 miles
hi, hope u can help...car makes a vibration noise when driving forward..only goes away when turning left but not right...thanks for a reply, jay |
Find a
car repair manual for your Dodge Neon Repair Question.
Posted at Thu Nov 19, 2009 3:42 am |
By
Service Writer,
Certified 2CarPros Master Technician |
               (7785) Give Feedback | Votes: 97 |
First thought is a wheel bearing issue. What speeds does that happen at? |
Find a
Posted at Fri Nov 20, 2009 10:25 am |
By
jason2004neon,
HI...from a slow start to any speed it makes the noise...when i go around a left turn it goes away...but not a right turn or when driving straight |
Find a
Posted at Fri Nov 20, 2009 10:56 am |
By
Service Writer,
IF it sounds like a roar, then it is probably a wheel bearing gone bad. Check for play in any of the wheels. |
Find a
Posted at Fri Nov 20, 2009 10:58 am |
By
jason2004neon,
Yes it is a roaring sound...recently rotated tires and did actually check for any play and seemed tight...should i go ahead and replace them anyways? |
Find a
Posted at Sat Nov 21, 2009 12:31 am |
By
Service Writer,
No, you need to determine which one is bad.
There may be play now as the pitting will continue to get worse. Generally you can tell which side it is coming from, if you can, then yes replace that bearing, if not you need to verify it....or risk replacing the wrong one.
You can verify it with a set of chassis ears.
You can also verify it if it is in the front by raising the front end in a safe manner, putting it in drive and comparing the two sides with a stethescope. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
