Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
2004 Chevy Tahoe V8 Two Wheel Drive Automatic 52000 miles
How do I change an air filter. I found where I go to change it, but not certain if I should remove the cover or not, it connects to a hose, and the cover is kinda hard to lift.
the hose connects to the top part of the filter box. There are four screws that fasten the top of the box to the bottom. Loosen these all the way (they will not come out but will be loose) then lift the top of the box, it could be snug (it is supposed to be to ensure no air leakage). Note the position of the air filter inside and replace it with a new one.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
