Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1995 Nissan Maxima Hard ...
Auto Repair1996 Nissan Maxima
Auto Repair2001 Nissan Maxima Car S...
Auto Repair1990 Honda Civic Heat Gauge
Auto Repair2005 Volkswagen Jetta Gl...
Auto Repair2001 Volkswagen Jetta Al...
Auto Repair2002 Volkswagen Eurovan ...
Auto Repair1995 Volkswagen Eurovan
Auto Repair1998 Other Volkswagen Mod...
Auto Repair1976 Other Volkswagen Mod...
Auto Repair1978 Other Volkswagen Mod...
Auto Repair1995 Nissan Pathfinder
Auto Repair2001 Other Volkswagen Mod...
Auto Repair1968 Other Volkswagen Mod...
Auto Repair2000 Honda Civic Overhea...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2004 Chevy Silverado 2004 Silverado Stalls And Dies
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu May 15, 2008 11:21 pm
By bluepitt, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
2004 Chevy Silverado V8 Two Wheel Drive Automatic 64,000 miles
Ok Here We Go I Have A 2004 Silverado With The 5.3 It Is Fly By Wire Throtle Body. The Truck Has Ported Heads, Headers, 4.10 Gears After Market Cam It Had The GM HD Transmition 4l60e In It I Changed The Throttle Body From A 75mm To A 80mm It Ran Fine. Then The Tranny Blew Up It Broke The Output Shaft In Half. So I Took It To The Transmition Shop They Built Me A Transmition With The Shift Kit 5 Planet Gears The Whole 9 Yards. The Converter Was Supost To Be A 2,700 Stall So I Got The Truck Back And The Truck Lacked Power And Was Not Shifting Right So I Bring The Truck Back To The Trans Shop They Tell Me The Reverse Gears Burned Up They Fix The Prob I Tell Them The Converter Is Not Right Does Not Feel Like A Stall Conv. The Converter Is The Same Housing I Had In The Blown Up Trans. So They Change The Converter It Looks Like The Same Sise As The Old One. The Truck Has A Clunking Noise When It Is At Idle And When Stoped And When Restarted Like A Shuter In The FlorBoard Area And Is Even Slower Than The Last Time. So I Bring It Back, The Teck Goes On A Test Drive With Me And Tells Me That He Cant Feel Nuthing Wrong So We Stop At A Light And I Tell Him That I Will Get On It One More Time, When The Light Turns Green I Start To Go And The Truck Just Reevs Up To 3000rpm And Wont Go!! So We Tow It Back. They Tell Me The Pump Gear Burned Up So They Replace It. The Converter Is Still Not Staling So I Get My Owne From A Aftermarket Dealer It Is A 9" 2,700 Stall Lock Up Converter. The Converter Noise Goes Away The Tranny Shop Fixes The Tranny I Get The Truck Back And The Stall Is Great But The Truck Surges And Some Times Dies When Applying The Breaks Even When I Coast To A StopThe Tuck Dies After The Lasd Down Shift ( It Does Not Die When It Is Cold)
I Have The Cooling Fan On The DARLE Two Coar Trans Cooler So It Is Not Geting Hot. And When At Speeds Of 30mph Or Greator When I FLOOR The Gas The Truck Starts To Rev Up And Just Cuts All The Way Out For A Split Second Then Catches And Away It Goes Then When I Reach High Speeds And RPM (The Rev Limiter Is Deleted) The Truck Cuts To Like 4cylinders And Says Reduced Engine Power And The Check Eng Light Goes On And The Coad Says The Throttle Pos Is Not Actual. But If I Dont Tromp On It All The Other Problems Are There With No Coads. I Have Checked The Fuell Press. It Is Fine. And When I Rev The Truck Up Slowley It Will Surge Several Times UP DOWN And Die If I Let Off The Gas. And Around 3,000 To 4,000 rpm In Neutral When Pushing The Gas Verry Slowley Down The Rpm Stays The Same Even When Pushing For A Short Moment. HEEELP!!!!!
Find a repair manual for your Chevy Silverado Repair Question.
By Advertisment,
Posted at Fri May 16, 2008 3:53 pm
By mastertechtim, Tech level 9
Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5Reputation: 245.5 (246) Give Feedback | Votes: 16
problem is either in the throttle body or the gas pedal. i just had a trailblazer with the same code and i flipped the coin and it landed on gas pedal and that fixed it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
