2004 Buick Rendezvous Water pump for the wash resevoir not
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2004 Buick Rendezvous 6 cyl Two Wheel Drive Automatic 75000 miles
When trying to clean/wash the front windscreen using the wash/wipers there is no water output nor a sound that the pump is functioning; Water resevoir is full and the rear washer functions correctly - thoughts that either the pump has failed or a fuse?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
