Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
2004 Buick Rendezvous 6 cyl All Wheel Drive Automatic 50000 miles
I have a leaking condenser and am in the process of replacing it. I have all connections removed but can't get the condneser out. Any ideas?
You have to disconnect a/c lines at the fittings (after evacuation) and remove the radiator and condenser together as a single unit. There are a couple bolts that hold the two together and are virtually impossible to reach unless you pull them out as a single unit.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
