Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1990 Acura Integra Seat...
Auto Repair1998 Pontiac Grand Am D...
Auto Repair1999 Toyota Camry Carmy...
Auto Repair1996 Plymouth Voyager Hey
Auto Repair2001 Ford Escort 0domet...
Auto RepairJeep Hardtop Wiring
Auto Repair1999 Pontiac Grand Am C...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2004 BMW 320 Diesel problem
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 26, 2008 4:48 am
By jmt1, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
2004 BMW 320 4 cyl Two Wheel Drive Manual 107000 miles
My 3 series 2.0td has an intermittent problem when accelerating. It sometimes stutters as though it needs time to think what it needs to do and then it goes like a bat out of hell! Any time engine under stress, ie going up hill it really struggles to get going, your foot could be to the floor and yet it won't accelerate! Diagnostics indicated airflow problem.
I changed airflow meter, local bmw garage now wants to change turbo, a turbo specialist says turbo is fine and now third garage says its either a map sensor or ecu!
Find a car repair manual for your BMW 320 Repair Question.
Posted at Thu Aug 14, 2008 7:19 am
By KHLow2008, Moderator
Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5Reputation: 178.5 (178) Give Feedback | Votes: 13
Hi jmt1,
After replacement of air flow was diagnostic done again? Does it show same code?
Did you check the wire connectors or circuits?
Posted at Thu Aug 14, 2008 11:43 pm
Yes when air flow meter replaced a further diagnostic was done and it was supposed to be clear. I did not check wiring.
A point to note is that the fault appears to get worse as the car gets warmer! When cold it appears surprisingly ok!!
BMW error code P3263 comes up now wehn a diagnostic machine is plugged into the car.
Posted at Fri Aug 15, 2008 4:41 am
Hi jmt1,
Sorry to say that I am not able to get any info on the code you mentioned.
Since the problem is more prominent after warming up engine, I would suspect it to be a bad connection somewhere, maybe the MAF or other connectors. Check for contaminations or corrosion among all the sensors sockets.
Posted at Wed Sep 03, 2008 6:36 am
Just returned from garage that used two diagnostic machines on it. Both say boost on turbo ok (1.0 bar I think the mechanic said) although there is an oil leak from it which looks to have been leaking for a while. Rest of settings ok apart from battery that reads 30 (ish) volts! Strange?
Electrics have been checked and seem ok!
Have changed middle cat exhaust but situation actually worse now. Fault continuous now except where car left to stand for few days then ok for a while! Car really strugggles below 2500rpm when warm especially when under more pressure such as going uphill. Once above those rpm the turbo kicks in and the car flies! Two mechanics looked at it today and are confused!
Posted at Sat Sep 06, 2008 5:02 am
Hi jmt1,
The next tihing I can think of is the fuel pump and injectors.
But the voltage is something you need to check out, there ought to be somethng wrong with the charging system.
Posted at Mon Sep 08, 2008 12:42 am
According to my friend who used two diagnostic machines everything is operating as it should!
Is it possible that when hot the turbo could stick when at lower revs and as such it needs more pressure to get it running? Hence poor performance at low revs? Could this be a result of poor lubrication as there is a very small leak of oil from the turbo.
The BMW dealership say it is the turbo and want to replace that first!
Posted at Mon Sep 08, 2008 5:52 am
Hi jmt1,
I would rate it as very unlikely, whereas the opposite would be morel likely, when cold it sticks and when hot it would run better.
What I mean is the fuel pump might not be supplying proper fuel pressure/volume at lower rpms thsu the lack of power at low rpms only.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
