Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1993 Honda Civic
Auto Repair1997 Vauxhall Astra Brak...
Auto Repair2005 Dodge Neon Check En...
Auto Repair1988 Chevy Cheyenne Firi...
Auto Repair1998 Jeep Cherokee Probl...
Auto Repair2001 Mitsubishi Galant D...
Auto Repair1993 Buick Skylark Stalling
Auto Repair2006 Nissan Altima Indic...
Auto Repair2004 Acura Tl Ac Stopped...
Auto Repair2001 Nissan Pathfinder Re...
Auto Repair1993 Ford Explorer Lights
Auto Repair1990 Geo Storm Timing Belt
Auto Repair2001 Ford Focus Leaky/ba...
Auto Repair1990 Dodge Ram Heater Core
Auto Repair1979 Chevy Van Reverse S...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2004 Acura TSX Slipping Clutch?
Posted at Tue Apr 22, 2008 10:24 pm
By agraves, Have Donated
Give Feedback | Votes: 0
Transmission problem
2004 Acura TSX 4 cyl Front Wheel Drive Manual 80,000 miles
I have an 04 Acura TSX 6speed. The Clutch i have has 30,000 miles on it. It goes into gear fine and everything seems to work fine. When im in any gear and i press the gas (usually at low rpms), the rpms just raise but the car doesnt go anywhere and then the car shakes alil and then it grabs. I dont think its the clutch slipping but maybe something else? I thought that the clutch would need to be worn for it to slip but it only has 30K miles. But like i said, everthing else works fine. I can go into gear fine.. its just that when its in gear i have to press the gas so lightly. And it does this even in cruise control! I also hear a faint squeel sometimes going into first gear and now when crusing in 6th gear. Sounds like a cricket when going 60mph in 6th gear. What can be the issue? Clutch? Throw out bearing? Master/Slave Cylinder?
Find a repair manual for your Acura TSX Repair Question.
Posted at Tue Apr 22, 2008 10:34 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8Reputation: 368.8 (369) Give Feedback | Votes: 11
Hi there,
Thank you for the donation.
Your symptoms are constant with a faulty clutch, the hydraulics sound OK, as you are able to operate the clutch and change gears, but it is a drivablity problem. This could well be the clutch plate is contaminated with either engine or gearbox oil which can cause this clutch slip you are experiencing, I feel that you will have to remove the box and inspect the clutch for damage or contamination.
Mark (mhpautos)
Posted at Wed Apr 23, 2008 7:38 am
mhpautos wrote:
Hi there,
Mark (mhpautos)
if i replace the clutch, will engine or gearbox oil contaminate it again if thats the problem? What will cause the clutch to have that oil on it?
Posted at Wed Apr 23, 2008 2:17 pm
Hi there,
If oil contamination is the cause of your problems, it will more than likely be the front gearbox oil seal, as the engine rear mail is behind the fly wheel and you would see oil leaking externally for this to be the case, you will have to pull the box ans inspect.
mark (mhpautos)
Posted at Wed Apr 23, 2008 9:28 pm
mhpautos wrote:
Hi there,
mark (mhpautos)
Ok, now if this is the problem, how would i go about fixing it? Will this be costly? Im gonna take it to the acura dealership and have them install a new clutch but will they be able to see this leak while replaceing the clutch? How should i go about having them fix the oil seal?
Posted at Wed Apr 23, 2008 9:40 pm
Hi there,
The oil leak if that is what the problem is, will be very visible, there is a seal for the input shaft and it is quite a simple job to replace it if require when the box is out, the seal should only be a few dollars and it should only take 15 Min to replace when the box is removed to inspect the clutch.
mark (mhpautos)
Posted at Thu Apr 24, 2008 8:56 am
mhpautos wrote:
Hi there,
mark (mhpautos)
Is this seal something i need to get from the dealer or is it a sealant that i can get from a parts store like Napa or AutoZone? Or should any shop have it on hand?
Posted at Thu Apr 24, 2008 4:09 pm
You should use a genuine seal for this, it wont cost very much.
Mark (mhpautos)
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
