Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1997 Toyota Corolla Eng...
Auto Repair1989 Jeep Cherokee No S...
Auto Repair1992 Toyota Corolla Cv ...
Auto Repair2004 Renault Scenic Dia...
Auto Repair2001 Renault Scenic Air...
Auto Repair1995 Jeep Cherokee
Auto Repair More Repair Topics...
Car Repair Advice by Professional Automotive Experts
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Volkswagen Jetta p0420 engine code
Posted at Wed Feb 03, 2010 11:08 pm
By basspro1978, New to the forum
Give Feedback | Votes: 0
Computer problem
2003 Volkswagen Jetta 4 cyl Front Wheel Drive Manual 99980 miles
i have 03 jetta with rebuilt engine just installed and p0420 code pops up. so i replace both o2 sensors and new cat. what should i do next this code is haunting me and i have to pass az emissions. dealer says clear code and drive for 200 miles to cycle the computer but engine light comes on at 40-80 miles thx
Find a car repair manual for your Volkswagen Jetta Repair Question.
Posted at Thu Feb 04, 2010 1:37 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1Reputation: 14829.1 (14829) Give Feedback | Votes: 348
DTC P0420: CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD (EXCEPT CALIF. EMISSIONS) Circuit Description ECM compares waveform of heated oxygen sensor located in front of catalytic converter with waveform of heated oxygen sensor located behind converter to determine if converter performance has deteriorated. If both waveforms change at similar rate, catalyst performance has deteriorated. DTC is set when both oxygen sensors have same amplitude after vehicle is driven for 5 minutes at 20-50 MPH. Possible causes are: l Defective catalytic converter. l Heated oxygen sensor circuit is open or shorted. l Defective heated oxygen sensor. Diagnostic Aids Using scan tool, read freeze frame data. Freeze frame records engine conditions when malfunction is detected. Diagnosis & Repair 1. If any other DTCs are displayed, diagnose and repair those DTCs first. If only DTC P0420 is displayed, go to next step. 2. Check exhaust system for leaks. If problem exists, repair as necessary. If problem does not exist, go to next step. 3. Check heated oxygen sensor No. 1. See DTC P0130: HEATED OXYGEN SENSOR NO. 1 CIRCUIT (EXCEPT CALIF. EMISSIONS) . If problem exists, repair as necessary. If problem does not exist, go to next step. 4. Check heated oxygen sensor No. 2. See DTC P0136: HEATED OXYGEN SENSOR CIRCUIT (SENSOR NO. 2) test. If problem exists, repair as necessary. If problem does not exist, replace catalytic converter. DTC P0420: CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD (CALIF. EMISSIONS) NOTE: Heated oxygen sensor No. 1 refers to oxygen sensor closest to engine block. Heated oxygen sensor No. 2 refers to oxygen sensor farthest from engine block. NOTE: For component location, see appropriate illustration in THEORY & OPERATION article. NOTE: For component location, see appropriate illustration in THEORY &Circuit Description ECM monitors heated oxygen sensor No. 2 (located behind converter) to determine if converter performance has deteriorated. If converter is functioning properly, heated oxygen sensor waveform switches back and forth between rich and lean more slowly. DTC is set when A/F sensor and heated oxygen sensor No. 2 have same amplitude after vehicle is driven for 5 minutes at 20-50 MPH. Possible causes are: l Defective catalytic converter. l Heated oxygen sensor No. 2 circuit is open or shorted. l Defective heated oxygen sensor No. 2. l Defective Air/Fuel (A/F) sensor. l A/F sensor circuit is open or shorted. Diagnostic Aids Using scan tool, read freeze frame data. Freeze frame records engine conditions when malfunction is detected. Diagnosis & Repair 1. If any other DTCs are displayed, diagnose and repair those DTCs first. If only DTC P0420 is displayed, go to next step. 2. Check exhaust system for leaks. If problem exists, repair as necessary. If problem does not exist, go to next step. 3. Check A/F sensor. See DTC P1130: AIR/FUEL SENSOR CIRCUIT RANGE/PERFORMANCE (CALIF. EMISSIONS) . If problem exists, repair as necessary. If problem does not exist, go to next step. 4. Check heated oxygen sensor No. 2. See DTC P0136: HEATED OXYGEN SENSOR CIRCUIT (SENSOR NO. 2) test. If problem exists, repair as necessary. If problem does not exist, replace catalytic converter. OPERATION article
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
