Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1992 Nissan Truck How T...
Auto Repair2004 Chevy Cavalier Rea...
Auto Repair1999 Chevy Blazer Fuel ...
Auto Repair2000 Oldsmobile Intrigue...
Auto Repair1984 Ford Crown Victoria...
Auto Repair1997 Dodge Intrepid Con...
Auto Repair2001 Ford Windstar Fron...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Toyota Sienna sliding doors
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Aug 24, 2008 9:03 am
By thatsnice99, New to the forum
Give Feedback | Votes: 0
Interior problem
2003 Toyota Sienna 6 cyl Two Wheel Drive Automatic 70000 miles
both sliding doors are locked and cannot be opened. the lock does not come out from the locked positiion. how do i fix....
Find a car repair manual for your Toyota Sienna Repair Question.
Posted at Thu Sep 04, 2008 10:27 am
By laurafarnam@yahoo.com, New to the forum
I have the same problem...only they lock occasionally and then work properly again.
Dealer has no idea...
Posted at Fri Oct 17, 2008 10:47 am
By jmzzll, Have Donated
Try resetting the ECU with this procedure.
A. The Main Power Switch (located on the left side of the steering column) MUST be
in the “OFF” position (red line not showing on the switch button).
B. Place the transmission selector in “Park”.
C. Make sure the right side sliding door is fully closed (manual operation).
D. Disconnect the 12V negative battery terminal and wait for more than one (1)
minute, then reconnect the negative battery terminal.
E. Turn the ignition switch to the “ON” position.
F. Push the power door MAIN switch “ON” (red line on the switch will be showing)
and wait for 10 seconds.
G. Open the sliding door by pushing either the power sliding door control button
(located on the right side of the dash by the radio or on the “B” pillar) or the
remote switch on the key ring and allow the door to open all the way).
Wait three (3) seconds after the motor stops running before proceeding.
H. Close the sliding door by pushing either the power sliding door control button
remote control button and let the door close all the way.
I. Repeat steps G and H.
IMPORTANT:
Steps G and H, described above, MUST be repeated.
J. Confirm proper operation of the power sliding door system
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
