Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Gmc Yukon Brake Pe...
Auto Repair1999 Chevy Malibu My Ca...
Auto Repair2004 Ford Falcon Coolant
Auto Repair1998 Ford Windstar Stal...
Auto Repair2003 Ford Mustang Servi...
Auto Repair2001 Chrysler Town And C...
Auto Repair1996 Ford Contour Led He...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2003 Subaru Outback Trans not in first gear at start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Sep 03, 2008 2:11 pm
By weedlawn, Have Donated
Give Feedback | Votes: 0
Transmission problem
2003 Subaru Outback 6 cyl All Wheel Drive Automatic 62000 miles
When I start uphill from a stop, the auto transmission seems to not be in 1st gear; I have to pump accelerator to convince it to down shift and move the car faster than a crawl. Similar problem at speed, but not consistently - and occasionally I feel a shudder as the transmission comes in and out of top gear at 40 - 50 mph. At 60K the fluid was changed. The shop just had the car a full day, and "didn't experience the problem" - but leaving the shop - I couldn't get up the hill from the parking lot until I stomped on the gas. With this low mileage, I shouldn't need a new tranny... could this be a vacuum problem?
Find a car repair manual for your Subaru Outback Repair Question.
Posted at Fri Sep 05, 2008 5:05 am
By KHLow2008, Moderator
Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2 (179) Give Feedback | Votes: 13
Hi weedlawn,
Thank you for the donation.
Kindly check if the following helps.
ON-BOARD DIAGNOSTICS SYSTEM FUNCTION
The on-board diagnostics system detects and stores in the form of a code a fault that has occurred in any of the following input and output signal systems.
If a fault has been detected, the system tells the fault by causing the AT OIL TEMP warning light to operate as follows: 
1. Repeated flashing at 4 Hz frequency ... Errors such as battery trouble 
2. Repeated flashing at 2 Hz frequency ... No faults in the system 
3. Flashing at different intervals and frequencies ... Diagnostic trouble codes of corresponding faults 
4. Continued illumination of light ... Fault in inhibitor switch, idle switch, or wiring
OPERATION OF AT OIL TEMP WARNING LIGHT On starting the engine, the AT OIL TEMP warning light illuminates and then goes out as shown in the "Normal" diagram below. If any problem exists, the warning light continues flashing as shown in the Abnormal diagram below.
Operation Of At Oil Temp Warning Light - Normal & Abnormal Diagram Courtesy of SUBARU OF AMERICA, INC.
DIAGNOSTIC TROUBLE CODES DIAGNOSTIC TROUBLE CODE
DTC Faulty Component
11 Engine speed signal circuit
27 ATF temperature sensor
31 Throttle position sensor
33 Front vehicle speed sensor
36 Torque converter turbine speed sensor
38 Torque control signal circuit
45 Intake manifold pressure signal circuit
71 Shift solenoid 1
72 Shift solenoid 2
73 Low clutch timing solenoid
74 2-4 brake timing solenoid
75 Line pressure duty solenoid
76 2-4 brake duty solenoid
77 Lock-up duty solenoid
78 Sports shift solenoid
79 Transfer duty solenoid
86 VDC communication
93 Rear vehicle speed sensor
AUTOMATIC TRANS - MECHANISM & FUNCTION -2003 Subaru Outback 9/5/2008 http://www.ondemand5.com/mric/common/asp/printart.aspx
Posted at Fri Sep 05, 2008 10:28 am
The AT light functions normally - no error code. The problem is worsening, though, with the transmission more and more often failing to downshift to accelerate. It's hazardous to pull into traffic.
Posted at Sat Sep 06, 2008 4:56 am
Hi weedlawn,
Since there are no error codes, you need to check the engine performance related items.
1. Throttle Positioon sensor.
2. O2 sensor.
3. Ignition timing.
4. MAP sensor.
Was any repairs/adjustment done prior to this happening?
Posted at Sat Sep 06, 2008 6:58 pm
Thanks - appreciate it. The car had its 60K service about two months ago, but this didn't start until last week.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
