Car Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Pontiac Grand Am wiill not start
Posted at Wed Nov 04, 2009 7:41 am |
By
bigboy49,
New to the forum |
Give Feedback | Votes: 0 |
Engine Performance problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 75000 miles
my car will not start when outside air temp. is below 50 degrees. above that it runs fine. i changed crank sensors, map sensor, wires, computer, tune up still will not start please help |
Find a
car repair manual for your Pontiac Grand Am Repair Question.
Posted at Wed Nov 04, 2009 8:22 am |
By
rasmataz,
Certified 2CarPros Master Technician |
        (8489) Give Feedback | Votes: 230 |
Do below and check what's missing fuel or spark
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
