Engine Performance problem
2003 Other Mercedes Benz Models 6 cyl Automatic 79405 miles
I have a 2003 E320 Benz with 80,000 miles. I have had regular service. But it smokes a little while ideling and using passing gear. The smoke is blue in color and coming from exhust pipe out of rear. No smoke from under hood. No running issues. All fluids are good could it be gasoline? What is this? Please help me!
Thanks
Ray
Find a
repair manual for your Other Mercedes Benz Models.
Posted at Sat May 10, 2008 1:26 pm
By
Advertisment,
Find a
Posted at Sat May 10, 2008 3:05 pm
By
blackop555,Certified 2CarPros Master Technician
wheres the smoke coming from?
exhaust? under the hood?
color? odor? al fluids good? no issues with running besides the smoke?
Thanks
Ray
Find a
Posted at Thu May 15, 2008 3:57 am
By
blue smoke indicates oil being burned, but since it is in such low quantities, it could be that your piston rings are slightly worn, but that is no problem. it could also be worn valve seals which could be allowing oil to get into the cylinder and burn.
Find a
Thank you so much for answering my questions!
Ray
Find a
Posted at Fri May 16, 2008 4:14 am
By
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
