Transmission problem
2003 Mitsubishi Montero 6 cyl Four Wheel Drive Manual 36000 miles
I have a 2003 Pajero/Montero, it has manual transmission.
I've noticed that whenever I put it into gear to start off, as I let go of the clutch I get a slight bump, same thing when I shift into 2nd, 3rd or sometimes even on 4th gear. But if I slowly let out the clutch and give it more gas I don't feel the bump much or sometimes there's nothing. What could be the problem? is it the transmission or the rear differential?
thank you.
