Auto Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Honda Pilot bouncing vibration
Posted at Mon Jul 06, 2009 2:44 pm |
By
ronmays,
Have Donated |
(14) Give Feedback | Votes: 0 |
Suspension problem
2003 Honda Pilot 6 cyl All Wheel Drive Automatic 157000 miles
My Pilot has developed a vibration in the front end. This has gradually gotten worse over the last two years. It doesn't occur every time we drive it but often; about 1/3 of the time. It begins as the vehicle accelerates normally from a standstill up to cruise. It starts about 25-35 mph and lasts about 4-5 seconds. It feels and sounds exactly like the front tires are rolling over rumble strips in the road. The front tires bob up and down and the steering wheel shakes up and down. It stops if I let up on the gas.
What could this be? |
Find a
car repair manual for your Honda Pilot Repair Question.
Posted at Tue Jul 07, 2009 6:39 am |
By
racefan966,
Certified 2CarPros Technician |
               (1629) Give Feedback | Votes: 32 |
Ok I would be doing some checking to see what is loose. I would check the front drive axles and front drive line ujoints. I would check the tires them selves have them rotated if needed to see if it moves to the rear if so it is a bad tire. I would check ball joints and front struts and front end bushing too. Can you tell what side it is coming from? I would first have the front tires checked and ballanced then rotate them see if moves this will eliminate it being a tire issure. Let me know how it goes. |
Find a
Posted at Mon Sep 21, 2009 6:17 pm |
By
jill6624,
New to the forum |
Have you figured it out yet, mine does the same exact thing? |
Find a
Posted at Mon Sep 21, 2009 8:42 pm |
By
KHLow2008,
                               (3201) Give Feedback | Votes: 48 |
Hi jill6624,
If you have not done anything yet, I would suggest checking the drive trains.
The symptoms seems to indicate imbalance in the drive axles. Check the propeller shaft U joints and CV shaft inboard joints. Lack of lubrication and wear would cause the problem described. |
Find a
Posted at Thu Oct 29, 2009 3:38 pm |
By
kng1818,
Has a wrench in each hand! |
(75) Give Feedback | Votes: 2 |
Maybe engine hesitation or surging under light acceleration, the engine will hesitates or surging around 30-60mph if you have a faulty EGR valve. |
Find a
Posted at Tue Nov 03, 2009 6:41 pm |
By
oliveheads,
Likes to hang around! |
| jill6624 wrote: | | Have you figured it out yet, mine does the same exact thing? |
Ours is too. 2004 Pilot..... anyone having any luck out there with some shudder type jerking or wind sounds coming from the engine? Sounds very simliar to the April 04 recall, but I can't find any help?
Thanks,
Oliveheads |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
